idle problem please help!!
Old Jan 25, 2012 | 06:49 AM
5runner's Avatar
sorry had to go to work did not get a chance to get on here but i fixed the timing felt and reset the distributor and i can get the idle down but when i put the timing to 10 dtdc it runs like crap but if i retard a lot it it runs like a champ i am very confused
Old Jan 25, 2012 | 07:36 AM
93toyrunner2's Avatar
12 to 14 degrees BTDC is the sweet spot on my truck, runs good, lacks some power (3.SLO!). Any more and I get poor gas mileage, from 17.5 down to 13.5 - big difference.
Old Jan 25, 2012 | 09:02 AM
xxxtreme22r's Avatar
I believe 10 BTDC with jumper in is the proper setting. Distributor should be right in the middle of it's adjustment when timing is at 0 degrees. If it's not then it's still a tooth off.
EDIT: Dang this is on a 3.0? Sorry, didn't see any mention of it. edited to reflect proper timing on the 3.0.
Old Jan 25, 2012 | 07:03 PM
5runner's Avatar
yea it s a 3.slow for sure and i am not sure any more i am getting pissed cuz i keep chasing my tail so i set it so it drives get and gonna leave it alone for a week and pic it back up next week
Old Jan 25, 2012 | 07:44 PM
  #25
ksti's Avatar
What did you retard the timing too? Could you be advancing instead, my experence the more you retard the timing the worse it seems to run just what I noticed on my 3vze
Old Jan 26, 2012 | 03:20 AM
  #26
5runner's Avatar
ksti i was moving it away form before tdc back past 10 degrees so i believe that is retarding it
Old Jan 26, 2012 | 01:18 PM
  #27
ksti's Avatar
Originally Posted by 5runner
ok so i pulled the distributor and it was a few teeth of so i fixed that a little better so i pulled the cam cover off and the t belt is off by 1 tooth so i think i might have find my problem
I saw this post did you do a timing belt recently or head gaskets? I find it odd that your distributor and TB were off
a few teeth if you didn't and (fixed a little better) probably is not properly fixed. You need to check your TB and Distributor again to make sure. Take your time and do one thing at a time.
Old Jan 26, 2012 | 05:42 PM
  #28
5runner's Avatar
well i did the head gaskets 2 and a half years ago but it was sitting for the past 2 years and now i am fixing her up and yes the timing belt is on right now and the distributor is on right but when i go to set the timing and jump the and e1 it dos not do anything(it is soposta retard it 8 degrees) some one told me that it might be a tps issue but i replaced it and set it right i pulled the tps off and checked it again i checked it with the specs fro the fsm
Old Jan 26, 2012 | 06:35 PM
  #29
5runner's Avatar
just went out and check my vane air flow meter i put the meter on what the fsm says will move in a way patter but when i do mine it dos not seem to have any patter could this be the problem?!
Old Jan 30, 2012 | 03:22 AM
  #30
5runner's Avatar
bump. anyone have any clue were to go now cuz it is still doing the 1700 rpm idle this is driving me nuts!!!!
Charecter1
Nov 6, 2023 10:08 AM
Eggslinger
Jun 8, 2019 03:32 PM
Alex Bessinger
Aug 31, 2015 09:17 AM
kyletbert
Jul 17, 2015 11:39 AM
Jnkml
Jul 6, 2015 01:20 PM
