I think I broke something wheeling...
Old Apr 5, 2016 | 07:43 AM
TheHaak's Avatar
Unhappy I think I broke something wheeling...
Hey all, to start off I have a 1990 4runner with a re-manufactured 3VZE with about 4k miles on it and 210k on the body. Last weekend I went camping and drove for 15 miles or so on the most potholed trails I've ever seen. Once we were at camp for a while I went to move my truck. It was in 4 high and I had to give it a lot of gas to move it and it would only move a couple feet before feeling like a wheel was locking up. Having had a few beers by then I figured the morning would be a better time to figure it out. In the morning, I tried a couple times to move it but no luck, I walked away then came back, tried again and it moved no problem.
Now fast forward to yesterday. I was on a slight downward slope in line to get on the freeway. When the car would roll forward a little I could feel something resisting and the car would stop rolling with no brake applied. I tried this a couple times and it kept stopping. Today I noticed the same thing when leaving my house. When I got to work I rolled down the window and could hear a high pitched whining noise coming from the front right of the truck. That's about all I know.
So does anyone have a clue what could be the problem? It drives fine on the freeway. I can't tell if it's taking a little more throttle than usual to get it going or if I'm being paranoid.
TLDR: Went wheeling, couldn't move the truck after being parked for a while. Now it won't roll on small hills and there is quiet whining sound coming from around the front right wheel.
Old Apr 5, 2016 | 07:50 AM
MudHippy's Avatar
Could be a lot of things. Brakes, wheel bearings, spindle/knuckle bearings to name a few.
Were the potholes full of water? Does it have ADD, or manual hubs?
Old Apr 5, 2016 | 08:27 AM
highonpottery's Avatar
Lide said, could be any number of things. Assuming you have open front diff? I'd jack up the front end and start poking around. Try rotating tire by hand with it off ground and see if you can pinpoint it further
Old Apr 5, 2016 | 08:41 AM
ZUK's Avatar
ZUK
Sticking right caliper? Check the condition of your rotors......make sure they don't have deep "ruts" in them. Check that right front brake pad to make sure it's not down to the rivets.
Old Apr 5, 2016 | 10:24 AM
TheHaak's Avatar
Quite a few of the holes had at least a foot of water in them. I believe I have ADD hubs.
Old Apr 5, 2016 | 10:29 AM
TheHaak's Avatar
I do. I'll give that a try when I get home from work and get back to you with what I see/hear. Regarding what ZUK said, I'll also take a look at the rotors and pads. My brakes work great but it's definitely worth a look.
Old Apr 5, 2016 | 10:42 AM
MudHippy's Avatar
If your CV to spindle/knuckle seal(s) are shot, then you probably got water in the spindle/knuckle and maybe the wheel bearings too. It sounds like water washed wheel bearings to me. Been there done that.
But with ADD your CVs are always turning, and the spindle/knuckle bushings(or bearings) might be contributing to some of the noise. Not very likely the wheel drag though...possibly...but I doubt it.
Old Apr 5, 2016 | 12:04 PM
TheHaak's Avatar
If there is water in the wheel bearings could that cause the drag? How can I check on the seal? I took a look at the assembly behind the hub and it's looking pretty gunky, hard to see anything going on down there...
Old Apr 5, 2016 | 12:50 PM
MudHippy's Avatar
Yeah...I let mine go a little too long and it started locking the wheel up completely. On top of the horridly loud squeal.
You take the CV shaft out and take a look at it. If they're(1 on the CV shaft and 1 one the rear of the spindle/knuckle) letting stuff get by into the spindle/knuckle you'll know. Should be nothing but clean grease in there.
What do you mean behind the hub? Like where the CV plugs into the back of the spindle/knuckle?
Old Apr 5, 2016 | 01:01 PM
TheHaak's Avatar
Sorry I didn't mean actually behind the hub but just the whole area around the spindle and CV. I just went and took a look with a flashlight in the parking garage. I don't have a lot of experience working on my truck, is this simple enough that I can probably do it myself? I looked through a few DIY's on replacing wheel bearings and such and it looked easy enough to disassemble everything.
Old Apr 5, 2016 | 01:35 PM
MudHippy's Avatar
Oh...it's not the easiest thing to do. The removing the CV half shaft part sucks. Good practice for replacing your CV boots though.
Replacing wheel bearings is pretty easy. And you should be taking them out and repacking them every so often anyways. Every 36 months according to Toyota. When was that done last? Dare I ask?
Old Apr 5, 2016 | 01:42 PM
TheHaak's Avatar
I'll have to go check my receipt folder when I get home but I believe the previous owner did it right before I got the truck a little over three years ago. He may not have replaced all of them though. Sounds like now may be a good time to figure out how to do it myself
zayne_g
11
Jul 16, 2016 03:26 AM
BajaRunner
Apr 8, 2016 11:50 AM
hatrabbit
Apr 3, 2016 02:59 AM
mc360
Mar 23, 2016 12:29 AM
Charchee
Mar 21, 2016 06:10 PM
