I just did compression on my 22re , What do you guys think
Old Feb 27, 2013 | 01:12 PM
rydholm11211's Avatar
I just did a compression reading on my 22re with the intake off and the exhaust off, and was getting 195psi across all 4? Is this good? I know the standard is around 175? And I use 24volts to turn over the engine? I have heard someone people saying 200PSI is too much, but I would not know why, That would just tell me that it is a really strong engine? Thanks!
Old Feb 27, 2013 | 01:48 PM
Oh and when I do it on only 12 volts I get a 175 across all 4 cylidners, but isnt there people running 200psi on all 4? Thanks.
Old Feb 27, 2013 | 02:25 PM
kelvinb's Avatar
i did a quick google search and came up with this
155-170psi
Factory Specs= 142 Minimum, 14psi variation between cylinders.
so your service limit is 140psi. as long as all the cylinders are above 140 and with in 14psi of eachother, i wouldnt worry about it
Old Feb 27, 2013 | 06:03 PM
vital22re's Avatar
totally a bro
As long as they are fairly even across the board, you're good. The higher reading could be caused by carbon build up. Or the head and or deck have been shaved from a rebuild.
Doug4320
Mar 24, 2018 10:11 PM
thefishguy77
Jul 30, 2015 10:59 AM
skoti89
Jul 8, 2015 12:05 AM
timmJ
Jul 7, 2015 02:01 PM
bryan34w
Jul 6, 2015 05:53 PM
