I got my 4.88's but need some help.
Old Feb 23, 2009 | 05:27 AM
Bobzombie's Avatar
So a got a hell of a deal paid 200 for the pair hub to hub!!
But the front 3rd needs rebuilt I havnt taken apart yet but the axle stub on the diff has a lot of play in it. So I am assuming it needs inner and outer diff bearings. Any experience or recomendations would be much appreciated!
Also the Toyo bearings are expensive even at employee discount. Is there a cheaper method, parts kit?
Old Feb 23, 2009 | 05:31 AM
crolison's Avatar
I'd let a profession rebuild the front, you have to have the right tools and know how to get everything into spec.
You can get a full install kit for the diff, should be around 100-120ish. Try calling east coast gear supply.
Old Feb 23, 2009 | 07:05 AM
Bobzombie's Avatar
Thanks!
anybody on here selling a kit
Old Feb 23, 2009 | 07:07 AM
abecedarian's Avatar
You might hit up Zuk (here on yotatech) or check his site: http://gearinstalls.com
Old Feb 23, 2009 | 11:33 AM
RaginYota's Avatar
I am in the process of rebuilding my SFA. I bought this kit ( http://www.marlincrawler.com/axle/fr...wheel-bearings ) from Marlin Crawler. I also used this site to do the rebuild http://www.4crawler.com/4x4/CheapTri...eRebuild.shtml .
Hope this helps.
Jeremy
Old Feb 23, 2009 | 11:48 AM
mikepr55's Avatar
I used the same website as raginyota to get my parts and rebuild my front axle instructions are very detailed. This is the first time I did anything like this and to tell you the truth it was pretty fun but for the gears you realy should let a pro do that unless you have a buddy that knows what they are doing like I did. My bud only charged my two thirty packs of CL but is youe rig ifs or solid axle?
Old Feb 23, 2009 | 01:30 PM
Bobzombie's Avatar
Sorry I thought I put that info in my post. Its ifs!
After reading ZUk's page I think I might not need a rebuild
apparently some slop on the pass side axle flange is normal.
I am going to test it tonight, also going to check contact pattern.
Old Feb 23, 2009 | 05:36 PM
ZUK's Avatar
ZUK
ya...there isn't alot you can do about that play on the passenger side.....just put a new seal in there and hope for the best.
Now, as far as the ring/pinion....maybe the carrier bearing pre-load is gone....and maybe the pinion bearings are still ok but are running loose also and it needs some PPL added back in with a new pinion seal there also.
How's the pattern look?
ZUK
zytra
Jan 24, 2019 03:16 PM
Badlander
Oct 10, 2015 08:05 PM
JookUpVandetti
Sep 30, 2015 08:58 AM
Shagool22
Sep 28, 2015 07:53 PM
LotOMiles
Sep 14, 2015 11:45 PM
