Hyper Extened CV joint
I have a 94 4runner SR5 4WD and I was in the middle of doing a BJ spacer lift and I hyper extended the inner CV joint. I was wondering if toyota used the tripod type ( aka trunnion) of the ball style joint.
The inner joint is a tripod joint. Just remove the axle make sure you still have enough grease in there, re-install the boot (if it's not damaged) with new clamps, then re-install the axle.
If the new lift is going to overextend the joint, you may not want to use that ball joint lift, OR, use a drop bracket in conjunction with the lift. Have you already installed manual locking hubs?
If the boot didn't tear, getting the joint re-seated is all you'll need to do.
I had a similar thing happen with Scuba's truck when he and I were attempting to install the bj spacers on his truck (truck RIP)- had to tip the spindle out so the ball joint would clear the UCA and the inner joint on the passenger side became dislodged. A little finesse and the joint went back in to place with no problems and no damage.
kawazx636
Oct 6, 2021 03:03 PM
FS[MidWest]: 1.5" ball joint spacers
4x4YOTA
Aug 23, 2016 09:08 AM
FS[SouthCent]: TX - 4Crawler Ball Joint spacers
crash813
Sep 27, 2015 07:15 AM
Odin
Sep 26, 2015 06:56 PM
