How to tell if rear leaf springs are worn
Old Aug 11, 2006 | 08:13 PM
T_BONE's Avatar
Was just wondering if there was any way of telling if the rear leaf springs were worn. The ass end of my toy is sagging a little bit and was wondering if the leaf springs were the problem or something else. The truck is a little lower in the rear.
T_BONE
Old Aug 11, 2006 | 08:25 PM
rebult junk's Avatar
are they flat when the turck is on the ground
Old Aug 11, 2006 | 09:57 PM
humanoid's Avatar
They're supposed to have a slight upward arch if you look at them from the side. If you don't see any arch, like mine, your springs are worn and you either need to get new leaf packs or have them re-arched.
Old Aug 12, 2006 | 09:26 PM
CoedNaked's Avatar
Is your rear end sagging?
Old Aug 29, 2006 | 06:32 PM
T_BONE's Avatar
Yeah, it is. I had someone look at the leafs and they are all good. They seem to think the tortion bars were tweeked b-4 I bought it. How do you tell?
T-BONE
Old Aug 29, 2006 | 07:02 PM
Saint_Berzerker's Avatar
If your rear is ok and the front is jacked up to much, just loosen (ccw) the torsion bars a little bit at a time to lower the front. I'd loosen 2 or 3 turns at a time and check.
Watch your bumpstop clearance and make sure you don't get any less than an inch or so. If you are already at an inch or less then I'd say your rear has to be sagging.
Old Aug 30, 2006 | 03:23 PM
T_BONE's Avatar
Yeah, I just looked at the bump stops and the upper bump stop has about an 8th inch clearance while the lower has a couple of inches. If I were to change this will I need a front end alignment again or not?
Peace,
T-BONE
By-the-way, thanks for the replies.
Old Aug 30, 2006 | 03:27 PM
Firefightertaco's Avatar
would puting an AAL help at all? Because mine a totaly flat now
Old Aug 30, 2006 | 03:33 PM
T_BONE's Avatar
I guess the tortion bars being cranked on explains why my rig beats the hell out of me in the back country off-roads. lol
T-BONE
88sasturbotoy
Jan 30, 2026 01:57 PM
Flying91
45
Apr 11, 2024 04:39 PM
Yotadawgjr
10
Aug 23, 2015 10:51 AM
terminator
Jul 27, 2015 07:13 PM
Nickdigg
Jul 7, 2015 06:04 AM
