how many miles are too many on rebuilding block
Old Nov 16, 2009 | 12:52 PM
JigsN Rigs's Avatar
ok so how many miles are to many on rebuilding a block? also since im going to be bringing it to the machine shop to get resurfaced what else should i look into. maybe boring it out some, if so how much?
what have all you got done to your blocks on a rebuild?
Old Nov 16, 2009 | 01:07 PM
surf4runner's Avatar
really depends on your goals for the new motor.
ive rebuilt motors that had over 200K on em. some i have no idea.
the more you do, the more its gonna cost. you ready for that bill?
Old Nov 17, 2009 | 03:43 AM
JigsN Rigs's Avatar
im ready for anything brotha.. the block i have right now has 263k on it.. i think. i can still see the hone marks in the cylinder walls but there are like these dark rings at the tops of the cylinder...
what i dont get is what gets weak on a block.. sure it may have a lot of miles but what gets weak. does heat weaken the cast iron.
Old Nov 17, 2009 | 04:17 AM
jimep's Avatar
It's not neccesarily how many miles, it's how much was it abused, or what was done to it before that caused a need for a rebuild. Some obvious things to check in the bottom end, crank journals, look for gouges, roughness or scratches, if so i'd replace. make sure it hasn't been decked or bored previously. u mention'd about the ridge in the cylinder, clean it up as good as possible and see if i can catch ur fingernail on it if so it will deffinatly need reamed and probably bored, wouldn't recomend anything over .040" over stock as the cylinder walls get too thin.. the deck height can be fixed with a thicker head gasket or a shim. I'd recommend a MLS head gasket like Cometic as u can get them in multiple thicknesses and it's more relaible than a shim. but the smaller the combustion chamber, the higher the compression so that means more hp. Just don't let the valves touch the pistons!!!! and higher octane fuel will be needed if u take it to far.
Old Nov 17, 2009 | 08:08 AM
olharleyman's Avatar
I'd say magna flux & hot tank it, bore the cylinders as little as possible ,align bore,have all surfaces checked for flatness,check the crank and rods
Old Nov 17, 2009 | 08:45 AM
JigsN Rigs's Avatar
there are no ridges on the cylinders.. there are just dark rings at the tops of the cylinders.. like brown stains. the rest of the cylinder s you can see the hone marks clear as day. how do i know if it has been decked or already bored??
oh yeah im talking about the 3vze and the reason im going to rebuild the block is because i busted a rod...
Old Nov 17, 2009 | 09:41 AM
shaeff's Avatar
You can thank Toyota for using a wicked good quality cast iron for their blocks. I've seen Toyota blocks with close to 300k on them, still with the cross hatch clear as day, and with no ridges at the top of the cylinder bores.
So long as you get proper machine work done, there's no reason not to rebuild what you've got.
Old Nov 17, 2009 | 10:02 AM
91_TOYOTA_4x4's Avatar
3.4 hehe it should be fine man. maybe bore it but ther shouldnt be anything wrong with the block, you should be able to rebuild that thing and put another 267k on her haha.
Old Nov 17, 2009 | 10:45 PM
JigsN Rigs's Avatar
Ok. Well there are no ridges what so ever on the block. Hatch marks are clear as day. I think I'm just going to get the block cleaned and surfaced.. How much would u guess that would run me
Old Nov 17, 2009 | 11:25 PM
I would guess $2-300 mine was $80 for the magnaflux and hot tanked, total of $570 for magnaflux hot tank, align bored, cylinders bored 20 over, freeze plugs installed, all surfaces decked flat, rod bearings installed and rods shot penned
Old Nov 17, 2009 | 11:36 PM
JigsN Rigs's Avatar
What is "rods shot penned"
Old Nov 18, 2009 | 04:36 AM
shaeff's Avatar
He means shot peened and straightened, I'm sure. It strengthens the rods.
Old Nov 18, 2009 | 05:39 AM
yep that is correct
bigjstang
Jun 2, 2025 03:56 PM
thefishguy77
Jul 30, 2015 10:59 AM
Coreyr384
Jul 10, 2015 11:13 AM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
Vargntucson
Jul 4, 2015 12:15 PM
