How loose should 22re timing chain be? (Loose guide also)
Old Mar 30, 2018 | 04:41 PM
BobJ's Avatar
22re clacks a bit at start up. Thought it was stretched chain/bad guides. Pulled valve cover and plastic guides look new. Driver side guide moves back and forth at top approx 1/16"-3/32". Is that normal?
Balancer pulley moves from 0-10 degrees back and forth with engine off. Is that normal? Any way to check chain stretch short of removal? There is a slight polish on valve cover oil baffle directly over chain.
Thanks
Old Mar 30, 2018 | 05:24 PM
92ehatch's Avatar
The crank pulley will move back and forth as the chain slack takes up. That is normal. You are not supposed to move it counter clockwise btw. As for the guide, I'm not sure if that is supposed to move any.
Old Mar 30, 2018 | 05:42 PM
BobJ's Avatar
Thanks. Definitely didn't want to turn ccw, won't be doing that again. Might have a surprise when I start it.
Nissan had little match marks on timing gear/head. If it lined up with one, chain was good. If it lined up with other replace stretched chain. Thought Toyota might have had similar.
Old Mar 31, 2018 | 12:08 AM
Co_94_PU's Avatar
Your FSM has specs, length and link count. It pretty much has to come off and be checked in multiple places.
The spring in the tensioner does wear out from 'fatigue" as well the head wears down over time, both lead to noise at start up..
Old Mar 31, 2018 | 08:56 AM
BobJ's Avatar
Thanks. Did see the procedure/specs in TSM and others. Can't see tensioner, but guides look brand new. D I D brand timing chain and a local rebuilder's sticker so rebuilt at some point, guessing non oem tensioner.
Is the drivers' side chain guide supposed to have movement at top? Bolt has been bottomed and definitely tight. Didn't come across that info in TSM or others.
Old Mar 31, 2018 | 05:59 PM
BobJ's Avatar
Remembered I had old shortblock and dug it out. Plastic timing chain guide was tight. Last person in this one put wrong length bolt in.
Old Apr 8, 2018 | 10:44 PM
toyodabro's Avatar
Ahh bummer. That sucks. Another thing to check (yay!)-If you want to go through the process of removing the timing cover, you can check the bolt torque on the tensioner. There's three bolts so uneven triangulation can be an issue here-if one of the bolts it too tight, it can strain the tensioner incorrectly and inhibit the tension bolt from sliding in and out of it's housing properly. If you're saying the guides were installed wrong, this would be good to look at.
davo247d
Aug 30, 2009 06:57 AM
1993toy
Nov 29, 2008 09:39 PM
1993toy
Nov 29, 2008 02:06 PM
Toyota4ever
Nov 10, 2007 05:10 PM
customcruiser
Oct 26, 2006 03:28 PM
