how LONG is a 3vze supposed to smoke after...
...finishing up a HG on it??
Thus far Ive changed the oil 3 times, the 2 last times I had chocolate milk and smoke. Thus far on this 3rd time the oil is still clear. But oddly enough the truck still smokes! How long is this supposed to last?
hmmm that makes me feel better, but what about the blue exhaust smoke that just wont quit? Should that have stopped by the time the truck warms up?
I had another thought. The gas in my tank is OLD, probably 8months and on its way to varnish. I thought I had drained it all out courtesy of the fuel return line being disconnected and running the fuel pump, but there was still some in the fuel lines and fuel rails. So I put about 3 gallons of new 93 octane in the tank, and again ran the fuel pump.
So if varnish is mixed with mostly brand new gasoline, will it smoke when combusted?
took about 30 miles of freeway driving to clear out a little 4 banger with a cat full of antifreeze after a head gasket failure. I was starting to get worried as well but once my friend returned from his little freeway trip it was all good. The cat can really hold the gunk and it takes forever to clear it out, you need to run it under load to get the cat hot enough to clear it out.
this has nothing to do with your smoke, but be careful of the 02 sensor. when headgaskets blow and coolant goes into exhaust it can ruin the sensor. just something to be careful of if you didnt already know.
thanks you guys are life savers! (or rather hair savers since I was getting ready to pull my hair out worrying about it! lol) I set the idle and timing today after work. Interestingly enough when you line up all the marks the engine will idle at 800rpm but the timing will be at about 20*BTDC. Well when I dropped the timing down to 10*btdc, and moved the idle back up to 800, the engine went from silky smooth idle, to a slightly lumpy idle!
Weasy2k's cams do impart a tiny bit of lumpyness afterall...its SOOO cool!!!
hmmm that makes sense but I had not thought about that! When the O2 sensor goes bad, will it still dither back and forth? Also how will I know?
I wouldn't think it would keep smoking much past a few minutes into a check ride.
I hate to piss on your parade, but it sure sounds like she's still leaking.
I would suggest performing a compression check and pressure test the coolant system.
Yea, it doesn't sound good.
SHOULD NOT smoke or have milkshake oil after 1st running up to temp.
Once it's hot and the oil's been changed it should look normal from there on out.
Is your coolant level changing?
All the plugs look the same?
O2 sensor should be replaced. It's not that much $ for what you get.
