How far can the 3.0 go?
Old Apr 23, 2009 | 11:47 PM
  #141
TNRabbit's Avatar
Originally Posted by dutchboy
Just turned 224,00 on my 90,3.0.
Oil pump replaced at 186,000.
Head gaskets were done about,oh...188,000.
Have some valve chatter and a slight miss,which I'm "assuming" is due to the valve chatter. 1000 miles back,did entire tune up,incuding fuel filter.
This past summer,replaced...starter,alternator,battery. Getting ready to change power steering pump. *ugh*
Not the greatest on power,but not the worst either. Not the greatest on mpg (15-17 city,17-19 hgwy),but it could be worse,right?
Slight miss after warmup is usually due to a vacuum leak.
Old Apr 24, 2009 | 07:09 AM
  #142
bigtrucknwheels's Avatar
Originally Posted by 5Runner89
i got 408k and change on the one that was just kinda put in my lap.
all original?
Old Apr 24, 2009 | 11:45 AM
  #143
91Toyota's Avatar
Originally Posted by space-junk
you speak like you know what your talking about trevor...
just crested 265K...
lol..just giving the 3.0 guys crap
Old Apr 24, 2009 | 11:54 AM
  #144
shore.runner's Avatar
Mine went 404xxxkm's
Until i sold her yesterday
Old Apr 24, 2009 | 04:46 PM
  #145
ThE-WhitE's Avatar
330 000 km all original! Match number 4Runner! No head gasket done and riding in Quebec's cold winter! Still running strong, not taking any oil nor coolant.
Old Apr 24, 2009 | 05:11 PM
  #146
what'd you do that for?
Old Apr 24, 2009 | 08:33 PM
  #147
Toyo4x4's Avatar
About to turn 177K on mine. A/C might have finally given up the ghost...its being looked at right now. H/G was done @ 60K. On my 5th set of tires as of last week (SMOKIN' deal...4 Michellin LTX M/S 31x10.5 for $167! They were starting to dryrot and still under warranty!)
My Mom has a '93 2WD V6 that has almost 300K. Hope it lasts a few more years as its definately showing some wear.
Old Feb 25, 2010 | 04:07 PM
  #148
83snowtruck's Avatar
I just hit 232,000. I bought it at 200,000. No idea of HG but runs awesome. I have done all new cooling system. All new front end. Wires,plugs,all that stuff. Getting ready to do seafoam treatment. then do oil pan. And do valve adjustment. That's the only real problem is the tapping... Quick ques: anyone run the E3K diamond fire plugs? Anyone notice higher engine temps or any engine difference from NGK plugs?
Old Feb 25, 2010 | 05:26 PM
  #149
jrobertson4runnner's Avatar
i have 371k on mine, completely stock, no HG at all.
Old Feb 25, 2010 | 06:19 PM
  #150
phildelfino's Avatar
231,XXX. Probably original HG.
Old Mar 1, 2010 | 11:22 AM
  #151
dsleggett's Avatar
167,000+, HG done under recall (Aug 98, 57k miles) Steering Relay rod done under recall (Aug 06, 126k miles). Nothing but routine maintenance, runs great. A/C started acting up last summer, I think it's a sensor but might be the compressor clutch. 19+ mpg consistently (since I solved the EGR puzzle), DD with 50 mile round-trip commute each day.
1/2/2011 update: 198,000+ now, still going strong, had a rough idle, significant missing under load issue last fall. Turns out when I changed plugs last most of the threads stripped out of cylinder 6 (or 3, closest to driver). One day the spark plug blew out, talk about loud, it was still held by the plug wire. I wrapped the plug with teflon plumbing tape, cranked it in and drove it home. I ran one of those taps in that bores out the hole a little bigger, then a threaded sleeve that sizes it for the plug again. Took about two hours taking my time, cleaning out the tap frequently. New plugs all around and new wires and it's like new again, getting 20+ mpg every second or third tank.
Old Mar 2, 2010 | 02:54 PM
  #152
Ebin's Avatar
281,000 and counting. HG done at 240,000. Valves have never been done. Still drive it to work 300 miles a week.
Old Mar 8, 2010 | 04:44 PM
  #153
blkyota's Avatar
220k currently. HG at 160,000 went ahead and rebuilt topend when did hg bottom end was great, broke a valve spring and drove on it for 10k until had time to fix. Everything else routine maint
Old Mar 9, 2010 | 10:20 AM
  #154
budro's Avatar
240,000 just did the hg
Old Mar 9, 2010 | 10:33 AM
  #155
mrddk92's Avatar
My truck has 266 and I did the hg last july at 255. I added cams and lce headers...stupid me didn't think I had to rework the botttom end. I should have. But oh well when it gives up ill just throw a 1uzfe in there. Most of the time I get about 220 miles to a tank but last weekend I got 300 by going 60 on the highway and drafting behind a big rig lol.
Old Mar 9, 2010 | 12:09 PM
  #156
rossboy83's Avatar
I have 165,000 on my 3.0. To my knowledge the HG has never been done.
Old Mar 9, 2010 | 06:32 PM
  #157
Thegotruck's Avatar
From: Sleeping in the back of the runner. Living where ever I park
205k on my 95 3.0 2WD runner! Running strong 21mpg highway. Headgasket leaks and injectors making alot of noise. Sugestions???
Old Mar 9, 2010 | 07:07 PM
  #158
nothing you can do to the injectors, just noisy and always will be. as far as the headgasket, drive it till she blows hahaha
Old Mar 10, 2010 | 07:22 AM
  #159
Thegotruck's Avatar
Yup i'm a dummy. Valve cover gasket not head. Praise ala. I hope I haven't screwed my self. The dealer said it's not under warenty and hasent been done befor so I hope iv got one of the rare ones that isn't affeced by the head gasket. Dealership recomended lucas injector cleaner. Any body agree, disagree, or have better ideas? Sugestions of the cheapest way to getmy valve gaskets done. I'm living on the road ska no shop. I'm tataly capable just don't have tools. Any body in CA want to help? Will work for work!
Old Mar 10, 2010 | 08:15 AM
  #160
Lucas makes some real good stuff. I run the oil stabilzer in my vehicles haha. 95 should have been under the recall, unless yours was one of the last to leave the factory with an updated set of headgaskets. I know my 90 wasn't covered, but thats because I had the asbestos head gaskets, and never had a problem with the engine haha.
