How do I know if the torsion bars are turned up?
Old 04-13-2018, 09:22 AM
Paul22RE's Avatar
Bought a 92 pickup a few months ago and noticed the upper A-arms are resting pretty heavy on the cracked bump stops. Truck does look higher than stock but really hard to tell with the small tires & does ride pretty hard. It has 28" tires (235/75/15) on 7" wide wheels and measurement from floor to middle of fender is 36.75". Thanks!
Old 04-13-2018, 12:02 PM
RAD4Runner's Avatar
Also compare distance from lip of 15-inch rim to lip of wheel-well with others. This will be independent of tire size.
Old 04-13-2018, 01:19 PM
Paul22RE's Avatar
That measurement is about 15", rear is about 14.75". I turned the bolts 3 full turns each and now front is 14.75". Do you know what that measurement is supposed to be out of the factory?
Old 04-17-2018, 03:50 PM
-Loki-'s Avatar
You can look under the truck and see how far the threads are sticking out of the top for your torsion adjustment.
Old 04-17-2018, 04:08 PM
Paul22RE's Avatar
Are the upper A-arms supposed to be resting so hard on the bump stop that that are halfway compressed (and cracked)?
Old 04-17-2018, 05:09 PM
RAD4Runner's Avatar
Need to compare measurement above with other members who have stock same year-model trucks.
Old 04-17-2018, 06:56 PM
Yotard's Avatar
On a stock truck your control arms are going to be close to level with the ground. The more downward they point the more the bars have been cranked.
Old 04-23-2018, 01:19 PM
RJR
RJR's Avatar
The attached file from the FSM shows the official factory way to measure suspension height. This is independent of tire size, inflation, sagging body mounts, bent fenders with missing trim, etc.
caleb
25
06-11-2004 06:59 AM
914runner
16
10-22-2002 10:07 PM
ropre
08-15-2002 10:39 AM
doink
08-09-2002 11:15 PM
Quick Reply: How do I know if the torsion bars are turned up?
