Horrible noise from the front end
Old Aug 3, 2009 | 09:34 AM
fresch's Avatar
91 4cyl 4x4 ext cab pu
Need your advice on this sound... Sounds like grinding metal, when in gear rolling forward and reverse, while in 2x have not tried it when the hubs are locked in 4x4. Does not make the sound when the clutch is engaged or in neutral.
Do you have any ideas on what this could be?
Thanks
Old Aug 3, 2009 | 09:53 AM
Lumpy's Avatar
Is there oil in the tranny or TC?
Old Aug 3, 2009 | 10:10 AM
fresch's Avatar
I have not checked the gear fluids.
How do you service the man. trany?
Old Aug 3, 2009 | 10:14 AM
Jay351's Avatar
Drain the trans, t-case and front diff fluid and replace.
They all use 24mm drain and fill plugs (make sure you can get the fill plug out first). Make sure there is no metal in the oil..
Old Aug 3, 2009 | 10:16 AM
fresch's Avatar
Do you think it is too late to recover the ignored drivetrain?
Old Aug 3, 2009 | 10:18 AM
Lumpy's Avatar
Time will tell...Get it filled and see how it acts, stay close to home.
Old Aug 3, 2009 | 10:23 AM
fresch's Avatar
The worst part about this story is my wife brought it limping home from a 1000 mile trip to Iowa. Who knows how long it had been grinding dry. She said it just started on our home road. Hmmm
Old Aug 3, 2009 | 10:25 AM
Lumpy's Avatar
Home road leaving or coming back?
Jay351's Avatar
Well, worst case, find a junker truck and grab parts from it. Stuff is usually cheap and is easy to replace...
Old Aug 3, 2009 | 10:27 AM
fresch's Avatar
On the way home
Old Aug 3, 2009 | 10:28 AM
Lumpy's Avatar
Well fill it up with Lucas and take it for a ride. I like this stuff. I use the heavy oil in the Diff's, trans, TC. I also use the fuel treatment seems to do well.
Old Aug 3, 2009 | 11:36 AM
fresch's Avatar
Could it be the pressure plate/ clutch plate?
Old Aug 3, 2009 | 11:42 AM
Lumpy's Avatar
I would not think so...if you have it in neutral engine off and drift does it make noise? clutch in does it make noise? then I'm thinking the gearbox. A throwout bearing will wine usually not grinding. If the clutch was slipping you'd have different noises.
Old Aug 10, 2009 | 08:50 AM
fresch's Avatar
the sound is gone
I changed the TC, trany, and both differential fluid and the sound is no longer audible.
Although, when I drove it around the block to warm up the fluids before changing I could not hear the sound. So for now the sound is gone.
Thanks for the advice!
Old Nov 11, 2009 | 12:30 PM
fresch's Avatar
The noise came back
I mentioned it on another post, but I took my truck into my buddies mechanic and he diagnosed it with the Carrier Bearing/ center bearing and the clutch =$2100. Ouch. Made me assess if I want to fix or flip...
I decided to fix it with the help of another buddy whom is more mechanically knowledgable that I. He drove it and was not convinced of the Tech's diagnosis. Because the sound goes away in 4th gear. Also, when idleing we could slightly hear the bearing whine but when we disengaged the clutch the sound went away slowly= Tranny?
So I found someone who wants to rebuild the tranny if everything looks reasonablly in good shape. We are going to replace the clutch at the same time. Although it did not look that bad. The tech is an ass. NOt sure if he even looked at it.
Old Nov 11, 2009 | 02:03 PM
Dope Fiend's Avatar
Well I highly doubt he dropped the transaxle too look at the clutch, you're correct in that assumption.
You might be better off looking for a tranny on craigslist. If you wanna save money that is.
Old Nov 11, 2009 | 03:14 PM
desertcamper67's Avatar
Throw out bearings make noise when the clutch is engaged. Sounds like the pilot bearing. There's a video on here about easy removal with wet tissues and a hammer and punch.
Sep 4, 2015 09:27 AM
Daneums
Aug 20, 2015 05:36 AM
razorman8669
Jul 12, 2015 12:13 PM
Jonny246
Jul 12, 2015 04:51 AM
toyoda8488
Jul 5, 2015 10:18 PM
