Horn!!!!!!!!!!!!
Old 01-31-2008, 09:38 PM
stevec8720's Avatar
Horn!!!!!!!!!!!!
ok i searched and coudent find anything usefull. OK my 95 pickups horn didnt work changed the horn wala it worked. one month later back at square one. Checked the fuse good checked the horn its works when you test it. now i dont hear a relay click like i hear im supposed to. i tryed to figure out where it is i know its by the kickpannel fusebox inside but only see one relay which isnt it. anyone please help! pics would be superb. i would like to get this horn to work with the original in steering wheel button. ANY ideas! thanks
Old 01-31-2008, 09:40 PM
stevec8720's Avatar
ohhh also contacts in steering collum are fine cant beep the horn at all no matter how the wheel is turned or if i try to ground the brass thing with the wheel off
Old 02-01-2008, 04:55 AM
Morphine's Avatar
This is from my personal experience but I lost my horns capability to "honk" a little while ago. I replaced he horn, it worked for maybe 2 or 3 test "honks". I ended up cutting the factory harness at the plug and just wired my own connectors to it. Mine looked really bad and I thought maybe over the 16 to 17 years thats she has been used, that maybe the connecting harness went. Well after by-passing the stock harness and just crimping some ends on her she has worked fine for 3 weeks now. Just a thought. Sorry I don't have a good way of testing for you.
-=Morphine=-
Old 02-01-2008, 09:15 PM
stevec8720's Avatar
any other ideas horn relay?
Old 02-02-2008, 04:27 AM
DIHOWARD's Avatar
check that its grounded properly.
same problem , moved the ground wire to different location, works fine.
Old 02-02-2008, 08:23 AM
ovrrdrive's Avatar
I could never keep a stock horn working either...
I replaced mine with this:
http://cgi.ebay.com/Kong-Train-Horn-...QQcmdZViewItem
It's my favorite part of the truck.
Old 02-02-2008, 08:36 AM
ozziesironmanoffroad's Avatar
almost 300 for a friggin horn?/?
Old 02-02-2008, 10:38 AM
ovrrdrive's Avatar
Actually it's over $300 for a train horn and a 3 gallon OBA kit to run it. You can get just the horn for about $140 if you bring your own air.
Like I said, I love it and IMO it was worth every penny for it...
Old 02-02-2008, 08:04 PM
stevec8720's Avatar
any cheaper options really cool train horn tho
Old 02-02-2008, 08:12 PM
eightnine's Avatar
damn that train horn sounds badass.. if i ever have burning sensation to blow 300 bones im getting one
Old 02-02-2008, 08:22 PM
linuxrunner's Avatar
Overdrive, is the train horn as loud as a real train horn?
If so that's nuts, we have a train that goes by our house over 1 mile away and i can still hear the horn easy.
Old 02-02-2008, 08:53 PM
312necro213's Avatar
ok
just replace it with a train horn. Bam people get the f out of the way!
Old 02-03-2008, 03:40 AM
ovrrdrive's Avatar
It's every bit as loud as a real one. It has the same pitch and tone as the Leslie 3 chime train horns do. I blew it at a train once and he blew back, they sounded exactly the same. If anything, mine was a little louder.
An old man cut me off once and I blew it at him. He locked up all 4 wheels and swerved off the road.
Old 02-03-2008, 03:57 AM
cgeorge's Avatar
oh man.. if I had the extra $$.. I would do it.. that is hilarious!
Old 02-04-2008, 09:20 PM
stevec8720's Avatar
check out some of these horn blaster videos lmfao
http://videos.streetfire.net/video/9...358f92ba00.htm
Old 02-04-2008, 09:22 PM
stevec8720's Avatar
also overdrive maybe could you show pics of your setup like where the air tank and horns are and stuff
Old 02-05-2008, 12:40 AM
ovrrdrive's Avatar
mussy01
12-13-2016 08:20 PM
xzen73x
09-14-2015 03:00 AM
Curbstomp336
08-30-2015 07:20 AM
ToyoToler
08-08-2015 08:43 AM
jimkoz26
08-05-2015 03:15 PM
Quick Reply: Horn!!!!!!!!!!!!
