holy seized up u-joint
Old Sep 10, 2007 | 07:12 PM
jjrgr21's Avatar
try the ATF/acetone mix
Old Sep 10, 2007 | 07:21 PM
waskillywabbit's Avatar
Use a hand grenade.
Old Sep 11, 2007 | 02:55 AM
isaac338's Avatar
hand grenade would work but the neighbours might get slightly upset at the shrapnel..
Old Sep 12, 2007 | 02:56 AM
ssupercoolss's Avatar
you know there is a tool for doing u-joints/ball joints. i highly recommend this tool, even if you are thinking you wont need it that often. after you use it once, you will wonder why you didnt buy one earlier. its basically a big c clamp you use to drive out the u joint with an impact wrench.
Old Sep 12, 2007 | 05:31 PM
  #25
TORTIS's Avatar
don,t get the one from harbor freight. it sucks. my yokes are tapered and the dang thing would slide off the end when i would start torquing down the nut . i finally gave up and broke out the sockets. you could make one out of a c-clamp and angle the end so it would not slide off, which is what i am going to do.
kawazx636
Oct 6, 2021 03:03 PM
pickle6415
Apr 14, 2021 06:20 AM
ladybugRC
458
Aug 21, 2020 10:41 AM
Odin
Sep 24, 2015 04:38 AM
seab1209
Sep 3, 2015 05:41 PM
