high idel
Old Nov 22, 2010 | 11:53 AM
onebatk's Avatar
high idel
i have an 87 4runner 22re 5 speed when i start it up when it is cold should it have a fast idel because mine does not it sounds like it wants to but never does
Old Nov 22, 2010 | 12:18 PM
99blackSE's Avatar
When you first fire it up I believe it will be around 1500-1600 then it will either rise or lower depending on intake temperature readings from intake system (AFM?). Qualitative descriptions don't really help us, give us a few numbers from the tach and we'll go from there.
Old Nov 22, 2010 | 12:33 PM
toyota4x4907's Avatar
Incorrect. It doesnt take temperatures from air. It takes temperatures from the coolant. And it doesnt even electronically read them. There is a wax valve, like a thermostat, under the throttle body that allows more or less air past it as the vehicle is warming up to "fast idle".
Old Nov 22, 2010 | 03:53 PM
onebatk's Avatar
when i start it . it is at normal idle 850 rpm does not go any higher
the temp out side is in the low 40s
Old Nov 22, 2010 | 04:12 PM
onebatk's Avatar
no but it takes forever to warm up
Old Nov 24, 2010 | 06:57 AM
toyotasaurus's Avatar
I have this same problem and was just getting on to post up a question! It's -3 out right now and when I start the truck it goes to ~750 and stays there. It's never had a cold-start high idle and I just hadn't gotten around to figuring it out.
Longbed 90
Mar 11, 2019 12:38 PM
justdifferentials
14
Jun 11, 2017 08:36 PM
Ktm526
Oct 7, 2015 05:14 AM
Boomer8404
Sep 17, 2015 07:59 AM
Boomer8404
Sep 10, 2015 09:01 AM
