High Compression Numbers
Old Feb 2, 2009 | 10:10 AM
Whiplash Willy's Avatar
I recently had my head rebuilt on my 22re (had a bad valve), and replaced the head gasket with a stock thickness gasket. Everything is running fine, but I just did a compression test and got 185-190PSI across the board. That is I believe that is about 20 PSI above factory spec. Will that cause any problems?
Old Feb 2, 2009 | 10:17 AM
874runnersr5's Avatar
did you hold the throttle at WOT?
Old Feb 2, 2009 | 10:20 AM
I did, unless my pedal needs to be adjusted.
Old Feb 2, 2009 | 10:29 AM
hmm... as long as each cylinder is in the same area as the others you should be fine.
I would be worried if for say, one was that high and the rest were low.
dumpster84
Apr 30, 2016 06:03 AM
the1998sr5
27
Nov 17, 2015 09:30 AM
justdifferentials
Just Differentials
Sep 17, 2015 06:14 PM
falcon4runner
3.4 Swaps
Aug 6, 2015 02:36 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
