High Compression
Old Jan 28, 2013 | 09:53 PM
A2theK's Avatar
High Compression
Got around to a compression test on my 22re the other day and found out I have pretty high compression. Cylinder 1- 200, Cylinder 2- 190, Cylinder 3- 200, Cylinder 4-197. I've been told before high compression is caused by carbon deposits stuck inside the combustion chamber/on valves and whatnot. Thought these motors should be around 140-180. It's been a real dog lately so I'm going to start running 91 in her now that I know how high it is. Has 215k on it. Is seafoam the best option to attempt to clean it out without tearing it all down?
Old Jan 28, 2013 | 09:57 PM
TrikeKid's Avatar
Unless it's pinging this "high compression" is not likely your cause since it's really only 10-15 pounds higher than spec. I like to run some Marvel Mystery Oil in my gas personally to help clear carbon deposits, or some GM Top Engine Clean used the way they outline. Never been a fan of SeaFoam myself, I can get kerosene cheaper without the fancy can.
Old Jan 29, 2013 | 07:10 AM
Marc's Avatar
Are you sure your gauge is accurate?
dumpster84
Apr 30, 2016 06:03 AM
Sean McAuley
9
Nov 8, 2015 12:26 PM
Jcrawl94
10
Oct 24, 2015 04:34 PM
RatOmeter
Oct 22, 2015 03:17 PM
Jason Webber
Sep 2, 2015 03:30 AM
