Helppp!!! Removing my crankshaft pulley!
Old Sep 23, 2010 | 10:53 AM
4xEnthusiast's Avatar
I made the mistake of not loosening my crankshaft pulley before tearing my engine down. I am trying to replace my timing chain. I have no access to air tools and have no idea how I am going to get it off. Please help! I need my truck fully operational by tomorrow evening. I need this done!
Old Sep 23, 2010 | 11:00 AM
myyota's Avatar
You can either put the transmission in 5th gear and try and break it loose that way, or use a socket and breaker bar with the breaker against the frame and tap the starter to break it loose, either way should work.
Old Sep 23, 2010 | 06:15 PM
BIGBOCK's Avatar
What myyota said for sure! Actually, I had a H E double hockey stick of a time trying to get mine loose. I finally had to heat it up with a torch and use the large breaker bar to break it loose as the PO had lock tight on it...yeah, I said lock-tight. Best of luck.
Old Sep 24, 2010 | 07:29 AM
scope103's Avatar
Once you remove that bolt, you still have to put it back on, and the spec is something like 181 ft-lbs. So using the starter, or a big impact wrench, or other such ballistic methods to remove it is not going to help you on rebuild.
There are many listings of easy-to-build "wrenches" for holding the pulley against the torque of your "breaker" bar. Here's one: https://www.yotatech.com/forums/f116...h-3vze-137934/
Old Sep 24, 2010 | 08:06 AM
sb5walker's Avatar
This post links to that one and a bunch of others: https://www.yotatech.com/forums/f116.../#post51555671
BTW that 181 ft lb spec is for the 3VZE, not the 22RE. The 22RE spec is 116 ft lbs.
Old Sep 24, 2010 | 08:49 AM
TNRabbit's Avatar
sb5walker to the rescue....again!
Dude, you know more about the 2nd gen Yotas than any 5 people I know!
Old Sep 24, 2010 | 09:12 AM
sb5walker's Avatar
lol. No, definitely not compared to some of the techs here. I know my veezy fairly well though, and since I just changed my timing belt I knew that 181 spec was for the V6 and I doubted that the 4 cyl was the same so I looked it up.
Blamalam
Mar 12, 2022 07:34 AM
Scatpac
May 25, 2017 06:47 AM
romex1
Aug 10, 2015 06:21 PM
TJWilly
Jul 31, 2015 02:05 PM
yoterr
Jul 24, 2015 04:29 AM
