help with surging idle 22re
Old Oct 31, 2009 | 09:24 AM
robert1965's Avatar
what are the most common problems to look for with the idle surging, when the engine is warmed up and how to fix thanks.
Old Oct 31, 2009 | 10:05 AM
DupermanDave's Avatar
Vacuum leak, high idle, coolant air bubble, or a bad TPS. Mine turned out to be multiple vacuum leaks on a few gaskets.
Old Oct 31, 2009 | 10:11 AM
Kiroshu's Avatar
Vac leak.... Intake manifold leak.... TPS..... Airflow meter.... Timing... idle speed wrong.... EGR....
Old Oct 31, 2009 | 10:21 AM
yotawars's Avatar
well its most likely tps, mine idels werid and because of tps and i just unplugged it a new one is 80 bucks its not worth it
Old Oct 31, 2009 | 10:59 AM
raydouble's Avatar
Have you tried adjusting it, using the FSM specs?
Old Oct 31, 2009 | 02:57 PM
I'd also suggest readjusting it. Mine was fine, was re-adjusted, was fine for a while and went out of whack again. So it needed readjusted. Not sure how it happened, but it fixed it.
Old Nov 1, 2009 | 06:28 PM
muddbogg21's Avatar
i would have to say tps thats what my problem was mine used to built up idle slowly then drop really fast
Old Feb 23, 2010 | 10:12 AM
yotawars's Avatar
i tryed readjusting according to the specs and it just made it worse, when i bought the truck i guess the guy done something to it, but it just unpugged it and it works fine now.
Old Mar 8, 2010 | 01:30 PM
rattlewagon's Avatar
so my idle just started doing this. where should i start? what and where is the TPS?
Old Jul 3, 2010 | 11:33 AM
helidriver's Avatar
mine doing the same thing. matter of fact i've had 3 22re's and they've all done it. but this ones starting to do it the most. what's the tps process for those of us who can't find a FSM....?
Old Jul 3, 2010 | 11:37 AM
4x4jeffyota's Avatar
my 22r does the same thing, its annoying
Old Jul 3, 2010 | 11:48 AM
Fixed Mine. THe idle was up too high. Turned it down and the problem went away.
Old Jul 3, 2010 | 12:26 PM
helidriver's Avatar
yeah, sits at idle slowly goes up to about 1300 then drops back to 500ish and starts up again. if i tap the gas it levels for a minute around 900 then slowly climbs again. turned the idle down but still does it.....
Old Jul 3, 2010 | 12:55 PM
in N my idle surges but if i have the clutch engaged it idles constant at 2000, but when I first start it up it idles fine. My truck has a carb. does it still have a TPS
Old Jul 3, 2010 | 01:56 PM
Dale813's Avatar
Mine just started surging too. just bought a used Throttle body off ebay.
Old Jul 3, 2010 | 07:07 PM
In the end, that's what fixed mine. A new RTV gasket and a replacement throttle body. My butterfly valve wasn't seating properly and was letting air sneak past at idle.
Old Jul 4, 2010 | 06:14 PM
Trainwreckinseattle's Avatar
Idle surge can be caused by a bad sensor. The best way to start out trying to figure it out is by checking your codes.
If no codes,
The main cause of idle surge that "I personally" have come across especially on the 89-95 22RE is the idle screw being dirty, it's passage being dirty, or the throttle plate being dirty.
It's fix:
on the very top left of the throttle body there is a large flat blade screw. Take it out, clean it. Then start the truck with your finger over the hole, then spray intake cleaner down the hole. This has now cleaned the screw, and the idle passage. This will allow you to properly set the idle. Put a little dab of oil on the rubber o-ring and put the screw back in. Next take off the plastic intake hose, spray a bunch of intake cleaner on a rag. Open the throttle plate and wipe everything as far back as you can.
Side note: Never just spray intake cleaner into the throttle body. The TPS is not a sealed unit. Cleaner can easily travel up the throttle shaft into the TPS. This can easily damage the Sensor.
Old Jul 5, 2010 | 05:57 AM
I think we need a sticky writeup on the proper steps for idle surging. #1 should be checking TPS, #2 should be checking gaskets, #3 should be checking gaskets again, #4 should be checking the throttle body and throttle screw, #5 could be rechecking the gaskets, #6 could be checking the butterfly valve on the throttle body and #7 should be checking the IACV.
Old Jul 22, 2010 | 06:50 PM
blueyoda's Avatar
subscribed
Old Dec 1, 2010 | 05:52 PM
smelm0's Avatar
thanks to you all especially trainwreckinseattle for his advice re:the idle screw or should I say screw up. my 22re was fast idling and surging and I tried all kinds of tps, etc stuff but the idle screw did the trick. thanks again or maybe not since now I have to go back to work.
