help with surging idle 22re
Old Dec 1, 2010 | 06:25 PM
Moonfish's Avatar
Originally Posted by DupermanDave
I think we need a sticky writeup on the proper steps for idle surging. #1 should be checking TPS, #2 should be checking gaskets, #3 should be checking gaskets again, #4 should be checking the throttle body and throttle screw, #5 could be rechecking the gaskets, #6 could be checking the butterfly valve on the throttle body and #7 should be checking the IACV.
And the crazy idle that only happens when you press the brake pedal.
Old Mar 1, 2014 | 08:30 PM
camo 93's Avatar
Hello everyone. Im new here and fairly new to Toyota. Im here seeking wisedom. My ride is a regular cab 22re. Idle surges when brakes are applied. Replaced booster which did not fix the problem. The great and powerful google sent me here. I have looked at this entire thread. I did the tape test for iacv. No help. Took out and cleaned idle screw and adjusted to approximately 900 rpm. Problem solved (temporarily). After the engine cooled; I started it again and the engine will barely idle 200 250 rpm. Adjusted screw again back to 900 (cold) As the engine warmed up again; idle climbed again to approximately 1300. Surging with brake again. Is this a tps problem??
Any help would be greatly appreciated.
Old Mar 2, 2014 | 09:29 AM
toyota4x4907's Avatar
Timing needs to be adjusted properly the adjust the idle screw. How's your coolant level?
Old Mar 2, 2014 | 03:12 PM
smelm0's Avatar
as far as my experience goes with a 91 p/u with a 22re engine goes, I found basically 3 parts that could impact the idle besides the set screws. they are the mass air sensor, the throttle position sensor, and, of course, the computer. if i were you I'd start with the cheapest part:that is, the tps. mas also over time will degrade too . the used ones from carbone tend to test out of spec but i did over time once receive one thru auto zone which was calibrated at the factory by an tech that I spoke with. you might just try to clean the area with a special cleaner available at walmart, etc. the computer can b gotten from salvage but its solid state and I doubt is the culprit. but you never know until you change it out if need b.
hope this helps.
good luck.
Old Mar 3, 2014 | 01:06 PM
  #25
hybridspecies's Avatar
If the surging happens only when at idle with your foot on the brake, then try adjusting the idle screw so the engine is running at 750 - 850 rpm.
smthwsn357
May 1, 2024 07:28 AM
montanatruck
Feb 26, 2017 07:07 AM
jake_v
Jul 22, 2015 03:17 PM
kcaudill
Jul 20, 2015 12:06 PM
kyletbert
Jul 17, 2015 11:39 AM
