help - shock hitting suspension
Old Aug 14, 2019 | 11:15 AM
AKZEP69's Avatar
installed 5" RC suspension lift - went wheeling heard a loud metal scraping noise when turning hard right uphill & found this - any ideas of how to prevent?
Old Aug 14, 2019 | 07:21 PM
old87yota's Avatar
You are probably not going to like this answer...
Maybe get rid of the lift?
Old Aug 15, 2019 | 04:56 AM
keycw's Avatar
5 Year Member
put that rough country where it belongs, in the dumpster behind the local smut shop. looks like the shock is rubbing that bump stop? have you tried calling rough country and asking them? looks like a design issue to me, did you have to relocate anything to squeeze that giant block in between your control arms? keep in mind that your suspension was never meant to be altered in such a way, so RC should have parts to move things around.
Old Aug 15, 2019 | 07:28 AM
AKZEP69's Avatar
I didnt do anything to fit lift block -
Only changes from as bought condition were doing lift & increasing tire size from 265/75/15 to Dynapro MT LT305/70/16 Alignment was good before changes and was done after too.
I did note that Shock was 1/4" from top of bump stop frame. I heard a loud scraping noise when I made a sharp right turn uphill into a driveway and thats when I noted the damage to shock housing.
Only thing I can think of is back spacers for the rims? Which are not OEM
Ive talked to RC and their "engineering" have yet to respond
FYI - I researched the hell out lifts -Emu, Procomp, Marlin, BJ spacers etc.. RC was the one I chose so I didnt have to pay half as much as the kit cost- in shipping costs!
The money not spent on lift has been applied to Detroit lockers and upgrading everything else in driveline, (re-gearing from 4.10 to 4.88's)
Old Aug 15, 2019 | 07:35 AM
rattlewagon's Avatar
Possibly a bent shock. Whats the other side look like? They should be the same
Is it scraping on the factory bump stop perch, or just the spacer block? .
Old Aug 15, 2019 | 08:23 AM
Robert m's Avatar
Could you take a picture maybe showing the whole setup? You cant make out much of what's going on in that pic.
Old Aug 15, 2019 | 08:47 AM
keycw's Avatar
5 Year Member
yes a better picture would help. as for the lift quality, RC has been around for a long time so I don't really have an issue with the materials, I just don't agree with drop bracket ifs lift. it doesn't gain you any wheel travel, and it usually causes more problems than anything imho. as someone stated above, if it wasn't doing it before and you hit a bump and now it is rubbing, you probably bent the shock.
Old Aug 15, 2019 | 08:56 AM
5 Fists's Avatar
Man, 5" is a lot of lift.. back when I had an '88 4runner with a 3" body lift, I could barely get in it! Couldn't imagine a 5", and the stress that could put on the suspension as well. Probably a bent shock as Rattlewagon and keycw said.
Old Aug 15, 2019 | 05:58 PM
AKZEP69's Avatar
No left side is fine - about 1/2" clearance
Old Aug 15, 2019 | 07:52 PM
AKZEP69's Avatar
i will post pix friday - im going fishing!
Old Aug 16, 2019 | 09:52 AM
AKZEP69's Avatar
left side
right side
Old Aug 16, 2019 | 10:03 AM
Looks like the bump stop drop block may just need to be turned around. Is the mounting hole in the middle or offset to one side? Looks like the pass side may stick out a little farther than drive side?
Its rubbing on the drop block right? Not the factory bumpstop mount?
Old Aug 16, 2019 | 10:15 AM
AKZEP69's Avatar
it's rubbing on bump stop mount
Old Aug 16, 2019 | 10:22 AM
AKZEP69's Avatar
could right side be sticking out causing the shck to rub becaiuse I installed manual hubs and vacuum locked the ADD ?
I am scratching my head at what cause is! - I'm going to pull shock this weekend and see if it is bent -
this aint 1st 4x4 "i've modified!
Old Aug 16, 2019 | 11:48 AM
Kolton5543's Avatar
Not saying their isn't a problem but I have never been impressed with rough country. They have always been poorly designed and components always smash into things. Had a Jeep XJ come into work one day with a 6" RC lift. The upper links on the front would knocked a hole in the oil pan about 3/4 of the way on compression.
Old Aug 16, 2019 | 03:55 PM
Robert m's Avatar
I'm wondering if the drop bracket for the lower control arms isnt centered correctly, which is causing the lower control arms to be pushed more to one side
Old Aug 16, 2019 | 07:53 PM
AKZEP69's Avatar
I'M going to pull shock this weekend and I'll check to see if itr is.
THX
Old Aug 18, 2019 | 10:02 AM
Co_94_PU's Avatar
Circle takes the square!
Assuming the frame is straight it's a simple tweak of the dropbracket install and a proper alignment.
You can have perfect caster, chamber, and toe and not be centered on the frame. A 4x4 friendly alignment shop might have pointed this out for you. A shop that does four wheel alignment has the tools to tell you your track is off.
You can poke at AKWheeler for a "professional" take on this, I could be wrong.
Old Aug 19, 2019 | 05:52 PM
AKZEP69's Avatar
due to a more pressing matter I didnt have time to remove shock yet!
Old Aug 21, 2019 | 08:23 AM
old87yota's Avatar
Oh dear....
That is not good at all!
Stay safe!
