Help o2 sensor
Help o2 sensor
Hey everyone I recently pulled out my 94 Toyota it's been sitting about 2 years started right up had a code for rpm signal which was igniter wiring got that fixed and o2 sensor code 21 of coarse it didn't run well didn't rev up and was running really rich. I drained the gas new plugs new fuel filter and pulled the o2 figured I'd try cleaning it since the stores were closed it was really black. But either way most of what I read the code come on after a while where mine is instant I can unhook the battery re hook it up just turn the key on and the code is there so is the o2 really bad and messed up or is there another problem
22re 5sp 2wd
22re 5sp 2wd
Code 21 is when there is an open/short in the heater circuit of the sensor. So it will not go into closed loop as quickly. So it is probably not the cause of your running rich.
But you can test the sensor: http://web.archive.org/web/201503060...42oxygense.pdf
Code 5?
whats code 5? I did fix mine. I believe 87 have a single wire o2 sensor. But I'm not sure on that. I had a 4 wire o2 sensor and one of the wires had no continuity in it like it was cut somewhere. It wasn't but I had to run a new wire
Harness?
So was your problem in the harness wire from the O2 connector to the ECU? I have the single wire to the connector to the harness. Not sure how many relays/fuse blocks it goes through to get back to the ecm? Thats what I want to check, the wires/harness to the ECM, because I changed brand new sensor (didn't test the old one figured it was 10+ years old and ready either way).
Hey, side note...... If I shake the ingnitor coil?......? Should I hear fluid in it???!?
Also, is there vacuum on the lower end in the crankcase? This whole thing is trying to figure out why I have a misfire situation and throwing a Code 5, O2 circuit/sensor/ECM. If my oil dipstick rubber seal is dry like a rock and shrunk could it be a vacuum leak source/"un-metered air source to cause a rich ratio and thus causing the O2 code trigger??? Top top end at the intake and at the brake booster vacuum is 17.5 steady, no leaks up top.
Yes there is fluid in the coil
there maybe a very slight amount of vacuum at the bottom of the crankcase from the pcv however that wouldn't cause it to throw any codes
onesojourner
49
Jan 19, 2008 08:00 AM
Lonny007
May 5, 2003 10:56 AM
