HELP!! my runner died :(
Old Jan 23, 2009 | 01:04 PM
Amnesiac's Avatar
Check the belt too. I had a loose belt give me issues like that before.
Old Jan 23, 2009 | 01:20 PM
1989toy4wd's Avatar
Actually its not a good idea to take the negative battery cable off the battery while running! On old cars without computers its fine, but the computer on newer vehicles sometimes controls the output of the alternator, so if it detects an open in the circuit, it might bump the amperage up and fry things!!!! Seen it happen, wasnt me (thank god)!!
IMHO its not a good idea, I wouldnt even do it on an old vehicle, its not worth it when you can take it to autozone and they put battery cables on it and test it, plus its free!!
Old Jan 23, 2009 | 02:12 PM
904runner-ohio's Avatar
So I was wrong. After much consulting with more knowledgeable friends, we found that it will crank all day long, and the alt is good. we narrowed it down to a bad fuel pump. It aint getting gas. we sprayed starter fluid in the intake and it started to run but quit right when the spray was cut off. Do fuel pumps crap alot on yotas?? I dunno if this thing has ever had a new one put in, but i would think not. How hard is it to drop a tank in one of these things??
Old Jan 23, 2009 | 02:22 PM
swaycleveland's Avatar
you DONT wanna mess with that tank! Boostin chick had a hell of a time gettng hers down. find a line close to the throttlebody and see if your getting gas up there.
then move back to the fuel filter ( also a &^%$)
im free tomorrow if ya need a hand.
under your back seat ( passenger side0 is a acess panel )
Old Jan 23, 2009 | 02:39 PM
  #25
Ok this is a tough one to explain. There is a hose that comes off a bow in front, ya know what? I have a camera Im gonna take a pic. I think this might be it. hold on a sec
Old Jan 23, 2009 | 02:44 PM
  #26
http://www.ncttora.com/fsm/1993/index.html
you just got a factory service manual
granted its a 93 pick up but it will work for most things
Old Jan 23, 2009 | 02:50 PM
  #27
Ok this hose comes from a box in front of the power steering reservoir. And it goes to the EFI system. Could this be the reason my baby aint gettin gas?? I was checking the hoses and this thing fell right apart. Friggin plastic!
Attached Thumbnails HELP!! my runner died :(-100_0029.jpg   HELP!! my runner died :(-100_0027.jpg   HELP!! my runner died :(-100_0030.jpg
Old Jan 23, 2009 | 02:57 PM
  #28
it might be. ill look at the manual myself
toyotas need their vacuum lines otherwise they dont run right so there is a good chance that might be ONE problem
did you pull a gas line near the throttle body ? see if your getting gas to it ?
Old Jan 23, 2009 | 02:58 PM
  #29
bigt's Avatar
you can check you fuel pump by jumping the connector in the diagnos box in your engine i think tis fp +b..
then if you car starts with this jumped its bad wiring or your afm which tells your fuel pump to come on when starting... if it still dont go.. WHEN IT JUMPED try turning the key but dont start you should hear the hiss of the pump..no hiss no pump!
Old Jan 23, 2009 | 03:00 PM
  #30
I dont know which line to pull. Thing is confusing to me.
Old Jan 23, 2009 | 03:03 PM
  #31
did you look at the link i gave you for the service manual
Old Jan 23, 2009 | 03:15 PM
  #32
I downloaded one myself and it says to take apart the cold start hose assy. I'll prolly do this tomorrow.
Old Jan 23, 2009 | 03:21 PM
  #33
gotcha, id bet money ( not mine lol ) that its dieing because of something wrong with a vac line
anyway just let me know if ya need a hand
Old Jan 23, 2009 | 03:29 PM
  #34
Sure will. Thanks alot for the help. Now and in the future.
Old Jan 24, 2009 | 10:15 AM
  #35
89whitetoyota's Avatar
From: Cincinnati, Ohio - Amelia is the exact place. There is no one else on this site from where I am. Seems like everyone is from Cali or Washington. I guess I need to move.
You can go right undewr the throttle body and take a 19mm w/ an extention and loosen the feed line to fuel rail, then have a buddy turn the key to acc, and see if your getting a steady stream of fuel should be able to fill a beer can in about a minute or so, this has always been handy for me, because you can see if the pump and sending unit are working, also you see if there is junk in your fuel lines (bad filter), it only takes a minute but you will need to replace the crush washer (5 to 60 cents) at AutoChevy. If you are getting good flow to the rail then you know it might be fuel regulator or injector issue.
This is just a cheap fast way to get an idea.
MTLroadierunner
Jul 15, 2015 12:58 PM
Jnkml
Jul 6, 2015 01:20 PM
wilbertd
Jul 6, 2015 07:39 AM
coryc85
Jul 6, 2015 04:07 AM
HRDC0R19
Jul 5, 2015 06:43 PM
