HELP - Fuel pump / fuel tank question
Old Apr 10, 2009 | 12:22 PM
av3fire's Avatar
Hi all,
i am the one with the 88 PU that has been having fuel issues...... i am trying to replace the fule pump..... drained the tank (that was fun) dropped the tank, and when i did i found this (i hope the picture is here) there were 2 sets of wires going to the top of the tank. one where the fule lines go ( i assume this is to the fuel pump) and another set away from the fuel lines (i assume this is the gauge). One of the 2 wires attached to where the fuel lines go in was broken. there was a large amount of green flake (oxidization ?) near by. The wire that is still attached looks to be the ground. attached to a screw that is attached to the metal plate that all the lines go through. the other goes to a small round disk (about the size of a nickle) that is about 1/4" tall and appears to actually be clear, or at least translucent.
What is this part? can i just soder the wire to it? or do i need to replace the whole disk?
I cant get the picture to paste here.... i guess i can email a pix to anyone that can help.
THANX
t
Old Apr 10, 2009 | 03:24 PM
desert-rat660's Avatar
thats the power wire to the pump, can you solder it?
Old Apr 10, 2009 | 03:40 PM
av3fire's Avatar
there was not very much left (almost nothing)..... it was covered in epoxy like the coating on a M&M.... pealed that away and sodered it to the copper center. turned the key and VOILA!!!!!! the pump whirred like a kitten.
i am going to mix up some 5 min epoxy and coat the whole thing again.... if it lasted 20 years from the factory, mine is sure to last a couple.
will be wheeling tomorrow and i get to return the $165 fuel pump for beer money!!!!
thanx agian all
t
Old Apr 10, 2009 | 03:55 PM
Flash319's Avatar
I had to do the same thing. I had nothing to solder to so I just glued it then epoxy. It lasted 4 years until I scraped the truck.
sandyota
Feb 4, 2021 11:16 AM
Sep 4, 2015 09:27 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
redneck17
Jul 17, 2015 07:44 PM
Tyler Cunningham
Jul 11, 2015 10:18 AM
