help finding thread on electric speedo
Old Nov 27, 2008 | 09:22 AM
hmmwv15's Avatar
Someone mentioned an electronic speedometer cable replacement in another thread, some sr5 cluster swap, I need that thread. Basically I know marlin sells this little thing:
But I will not be swapping an sr5 cluster in. Is there another electronic sensor that plugs into the stock cluster?
Basically, is there any way I can convert my stock cable into an electric sensor?
Old Nov 27, 2008 | 09:26 AM
abecedarian's Avatar
pretty sure, for your truck, you'd have to change out the spedometer itself to get an all-electric speedo.
Old Nov 27, 2008 | 12:11 PM
Flash319's Avatar
You have to change the cluster. Not a very hard thing to do, just have to find one.
Old Nov 27, 2008 | 06:18 PM
anotherjeff's Avatar
OP has '87 Truck and '85 4Rnr. NO electrical speedometer clusters for those years.
Old Nov 27, 2008 | 07:15 PM
hmmwv15's Avatar
I know neither of mine are electric and from the looks of the above posts, they know also...I thought there may be something I could install in the cluster...
which is the earliest year cluster that offers an electric speedo? Shoot, I'll probably just get one from the stealership.
Old Nov 27, 2008 | 09:16 PM
Oh, I get it! Swapping speedometer heads, like Abe said!
As in, sacrificing a later cluster for the speedo head, to be installed in your cluster; then a little wiring harness from the new sender.
I think the Marlin sender is an equivalent to the OEM electrical sender.
Good question re. Introduction Date (of the electrical speedo)! Anecdotes suggest '92 model year (for Trucks, 4Rnrs are different...).
(Does TOYOTA Inc know the switchover date, and/or, VIN? Does anyone know?)
And, ...I just have a feeling that the listed price of an OEM cluster will be close to the price of a good used Toyota Truck. Anybody know?
Old Nov 27, 2008 | 09:42 PM
YoterUp's Avatar
Im stuck in the same situation i just swaped a 93 motor and drive terrain to my 90 truck and my spedo cable is mechanical and the plug in is electrical! i still havnt found a way around it yet other then change it all out to electrical im just not really in the mood to rip my whole dash apart!
Old Nov 27, 2008 | 11:14 PM
I believe that the mechanical sending unit interchanges with the electrical sending unit. That is, the flange and the drive gear on the tailshaft will accept either unit.
Old Nov 27, 2008 | 11:21 PM
khoopes's Avatar
Interesting concept. I wonder if you could tap into the speed sensor on a Digital Turbo cluster and feed it with an electric cable?
sandyota
Feb 4, 2021 11:16 AM
coryc85
Sep 9, 2015 06:24 AM
Yota.Jay
Jul 23, 2015 08:08 PM
Poncho0206
Jul 10, 2015 06:21 PM
AaronM
Jul 8, 2015 07:15 PM
