Help with E-brake indicator light
Old Jan 17, 2008 | 04:22 AM
Gavy's Avatar
Hey guys got a relatively small problem but was wondering if anyone could help me out recently my e-brake indicator light started coming on while driving and then it will go off for a few seconds and then pop back up again it keeps happening like that till the truck it shut off I use my e-brake a good amount but i have checked and double checked and it is not engaged i thought maybe it was sticking but that too seems not to be the case does anyone know why the light would be going on and off like that any help would be great
Thanks
Old Jan 17, 2008 | 06:01 AM
UncleBob's Avatar
Did ya check the tiny microswitch under the brake handle?
Old Jan 17, 2008 | 06:13 AM
my4runner's Avatar
Check your brake fluid as well.........
Old Jan 17, 2008 | 06:18 AM
04 Rocko Taco's Avatar
My guess is low brake fluid, check the master cylinder, and top it off to be sure.
Old Jan 17, 2008 | 06:50 AM
Gavy's Avatar
I did not check the micro switch but i did check the fluid and it is fine its sitting at the max level
Old Jan 17, 2008 | 07:35 AM
Then my guess would be the switch, or the fact that the handle is hanging out just a little bit on your e-brake.
Old Jan 17, 2008 | 09:40 AM
Gavy's Avatar
How do I go about fixing those problems if it indeed is one of the possibilites you mentioned thanks for the help
Old Jan 17, 2008 | 09:49 AM
toomanytoyotas's Avatar
This link has some good info on repairing that tab if it is broken. It may help.
https://www.yotatech.com/forums/f116...acable-133872/
Old Jan 17, 2008 | 11:57 AM
UncleBob's Avatar
Look under the console, where the E-Brake goes into the firewall. You'll see a little nob on the e-brake shaft that hits a little microswitch. It's one of the things that turns that light on/off.
Pull the E-Brake out. The light on the dash should go on. Push on that little microswitch while you're looking at the light on your dash. It should go out. If I remember correctly, it's adjustable.
Old Jan 17, 2008 | 12:28 PM
Gavy's Avatar
Awesome thanks man
AkitaDog
Sep 1, 2015 08:05 AM
yipyip45
Aug 6, 2015 02:05 PM
ddg71
Jul 24, 2015 01:24 PM
shisha1999
Jul 13, 2015 11:09 PM
