Help with clutch?
Old Feb 8, 2013 | 12:22 PM
rgnhd's Avatar
Okay so I found this clutch set at my local O'reilly's for $100. Would this be okay?
http://www.oreillyauto.com/site/c/de...ord=clutch+set
Old Feb 8, 2013 | 12:58 PM
Bullet22r's Avatar
i spent about 250 bucks on my clutch replacement and comes with the clutch kit and flywheel and rear main seal, my clutch set was LuK but when i went to check the brand both clutch and pressure plate were aisin i mean what luck! and while i was in there i changed the input shaft seal on the transmission
Old Feb 8, 2013 | 01:26 PM
derockus's Avatar
I got the Marlin 1200lb HD clutch kit, I'm digging it.
Old Feb 8, 2013 | 02:01 PM
Philbert's Avatar
SACHS kit you found is fine, and I considered it...but since I was going to the trouble of getting in there, I decided to spend a bit more and go AISIN (OEM brand). To each their own.
All the advice about replacing the rear main seal, input shaft seal, etc when in there is sound - cheap insurance and you might as well while you're in there.
In one of my writeups I linked to, there's a cool trick I used (not my idea) to remove the pilot bearing from the crank using wadded up water soaked pieces of scrap paper and a small socket - really made it easy.
Old Feb 8, 2013 | 02:26 PM
  #25
derockus's Avatar
Yeah, that looks like a slick way to get that sucker out of there!
Old Feb 15, 2013 | 03:12 PM
  #26
rgnhd's Avatar
Sorry for being gone for a while. Had the flu. Got the clutch kit today and just got done jacking up the truck.
Old Feb 15, 2013 | 04:55 PM
  #27
Bullet22r's Avatar
Tell us how everything went afterwards GOODLUCK
Old Feb 15, 2013 | 06:23 PM
  #28
rgnhd's Avatar
Alright. So I'm close to dropping my tranny and I've taken off my shifter. Now I have for a while now been driving with my transmission a little funny. Mainly my 3rd and 4th gear tend to feel like they're not going in all the way. They still engage they just don't go in like they used to. Now when I took my shifter off I found what appears to be little rubber pieces in there. I have to pictures showing what it looks like when you look in the hole where the shifter went. Do you guys have any idea where that came from?
Attached Thumbnails Help with clutch?-photo-2.jpg   Help with clutch?-photo-1.jpg
Old Feb 19, 2013 | 11:45 AM
  #29
cordrayj1's Avatar
is it possible a disintegrated one of these: http://www.marlincrawler.com/sites/a...s/seats640.jpg
Old Feb 19, 2013 | 12:14 PM
  #30
Philbert's Avatar
Cordrayj1 is right...there is supposed to be a bushing that sits in there on top of the 2 pegs you see. If you don't have one, that crunched up mess you see is what's left.
get a new seat from Marlin - they are $10 (made a huge difference in the slop of shifting). The smaller chunks you see shouldn't hurt anything inside - they will get crunched up more, smaller, and settle at the bottom of your transmission.
Old Feb 19, 2013 | 09:03 PM
  #31
rgnhd's Avatar
Alright, thanks so much guys. While I have the tranny out I'm going to do this. I was hoping that was it.
Old Feb 19, 2013 | 09:51 PM
  #32
cman1's Avatar
there is also another small white bushing on the end of the shifter ball that goes into the trans,that will probably also be missing or extremely worn,when you replace the shifter seat,replace that one too,marlin has both! makes a huge difference!
kawazx636
Oct 6, 2021 03:03 PM
primordialbeast117
Dec 19, 2015 12:23 PM
smilen724
13
Nov 8, 2015 04:11 PM
hiluxinargentina
Sep 30, 2015 11:12 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
