Help before I sell it
Old Dec 23, 2005 | 03:11 PM
yelloyota's Avatar
yep coolant is full still have the same problem
Thanks tho
Jeff
Old Dec 23, 2005 | 03:16 PM
Elton's Avatar
hmm im all out of ideas
Old Dec 24, 2005 | 02:37 PM
jrfast's Avatar
have you tried to repalce the o ring on your idle screw. count how many threads you unthread it and write it down. It probably looks like a square seal but it is not, it is an o ring that is most likely worn and causing an air leak. find a o ring that fits and seals tight before you put the screw back in put a few drops of blue loctite on it. it will seal the air leak and keep it from moving in and out on you. hope this helps Joe
Old Dec 25, 2005 | 04:00 PM
Elton's Avatar
if you want you could run down to autozone and see if its throwning codes
Old Dec 26, 2005 | 04:34 PM
  #25
yelloyota's Avatar
I'll keep you posted on what I find.
Thanks Guys for all your help
Jeff
kawazx636
Oct 6, 2021 03:03 PM
TheBFA
Feb 15, 2020 06:55 AM
primordialbeast117
Dec 19, 2015 12:23 PM
irv
Sep 29, 2015 01:04 PM
toyotasaurus
Sep 24, 2015 03:30 PM
