Help air conditioner leaking inside passanger side
Old 07-19-2010, 04:34 AM
Blk63vette's Avatar
Hello
While driving back to Georgia I noticed my carpet was wet on passanger side and water leaking underneath where the ac stuff was. ( it wet and cold condensation?). I know there is a line that lets the condensation leak out outside the truck cab. Where is this line on a 1994 Toytota 22RE 2WD truck. How do I clean it out??
Thanks
Pete
Old 07-19-2010, 05:32 AM
Blk63vette's Avatar
ttt
Old 07-19-2010, 02:35 PM
TORTIS's Avatar
your drain line is most likely clogged. shop vac and a piece of wire should knock the stuff out. Go easy with the wire. I used a brush that cleans out the drinking tube on Camel Back Hydration systems.
Old 07-19-2010, 06:41 PM
aquaprice's Avatar
My 94 was doing the same. The hose slips off, one hose clamp later no more problems.
Old 07-19-2010, 07:23 PM
Blk63vette's Avatar
What is brush that cleans out the drinking tube on Camel Back Hydration systems?
Old 07-20-2010, 03:43 AM
Blk63vette's Avatar
Hello
Im not sure which hose you are talking about?
Thanks
Pete
Old 05-02-2011, 11:18 AM
tardman91's Avatar
Where is this hose? Anyone have a photo?
Old 05-02-2011, 12:20 PM
tardman91's Avatar
I found it. For anyone wondering it's tucked right up inside the front passenger wheel well. It's a little silver metal tube that's right behind a rubber flap, at least on my '94.
Old 05-02-2011, 12:32 PM
NicCantDecide's Avatar
No photo, but behind the dash is the evaporator (which is what the air passes through to get cold). It's a black box. At the bottom of it there should be a tube going through the firewall. This tube is the drain tube that gets clogged or falls out and causes water to spill on the carpet.
If the clog is in the box, you can pop the bottom of the box off I believe, but its pretty cramped in there.
If the clog is in the tube, just take canned air or a pipe cleaner to it, its only a foot or two long I think.
If the tube just fell out... stick it back on, but make sure its not clogged first.
MO transplant
04-23-2023 11:58 AM
jon.r
07-11-2015 03:34 PM
87blyota
07-10-2015 04:31 AM
Avenged
07-09-2015 07:55 AM
bryan34w
07-06-2015 05:53 PM
Quick Reply: Help air conditioner leaking inside passanger side
