Help air conditioner leaking inside passanger side
Hello
While driving back to Georgia I noticed my carpet was wet on passanger side and water leaking underneath where the ac stuff was. ( it wet and cold condensation?). I know there is a line that lets the condensation leak out outside the truck cab. Where is this line on a 1994 Toytota 22RE 2WD truck. How do I clean it out?? Thanks Pete :domo2: |
ttt :saw:
your drain line is most likely clogged. shop vac and a piece of wire should knock the stuff out. Go easy with the wire. I used a brush that cleans out the drinking tube on Camel Back Hydration systems.
My 94 was doing the same. The hose slips off, one hose clamp later no more problems.
Originally Posted by TORTIS
(Post 51502881)
Originally Posted by aquaprice
(Post 51503100)
Im not sure which hose you are talking about? Thanks Pete |
Where is this hose? Anyone have a photo?
I found it. For anyone wondering it's tucked right up inside the front passenger wheel well. It's a little silver metal tube that's right behind a rubber flap, at least on my '94.
Originally Posted by tardman91
(Post 51714477)
If the clog is in the box, you can pop the bottom of the box off I believe, but its pretty cramped in there. If the clog is in the tube, just take canned air or a pipe cleaner to it, its only a foot or two long I think. If the tube just fell out... stick it back on, but make sure its not clogged first. |
