Help!!! 1989 Pickup has trouble on cold starts
My 1989 pickup with the 3.0 V6 has trouble staying alive on cold starts without gas and has a fair amount of gas coming out of the exhaust... after running or rough driving for 15 minutes its fine. I cleaned the throttle body, replaced the spark plugs, cleaned the throttle body and replaced the fuel filter as well as the rotor/cap. Is this an injector issue?
my wild guess would be that if a cylinder isn't firing, but the injector for that cylinder is squirting gas, it could be passing unburned fuel out the exhaust? if the fuel in the cylinder was too rich but the plug was firing, i'd expect to see black smoke.
sounds like it clears up tho, so how to troubleshoot for it? did any of the old spark plugs look different from the rest?
how about checking to see if it's throwing an error code?
