Header question for 3.0
Old Nov 20, 2008 | 07:10 PM
  #41
Elvota's Avatar
Originally Posted by truckmike26
Oh, by the way, I know about O2 sensors and closed-loop electronic engine controls.
Now I am curious. How would you handle the O2 sensor with a dual exhaust?
(since tone in type can be hard to "read", I am not being sarcastic... I'd really like to know)
Old Nov 20, 2008 | 07:34 PM
  #42
khoopes's Avatar
If you knew the impedance parameters and signal strengths of the circuit you could probably work up an interface circuit to sum the dual O2 sensors.
I had a 3.0 truck with headers and 32"s and a 3.0 truck with 31's and they performed similar, but the one with headers (and K&N) would tach out much faster. Definitely more responsive. I think if it had been on 31's it would have really moved.
Old Nov 20, 2008 | 09:38 PM
  #43
bigtrucknwheels's Avatar
+1. I could write a program on a microcontroller that would sum the signals and output their averages.
pretty cool what you can do, actually.
Old Nov 21, 2008 | 07:06 AM
  #44
trbizwiz's Avatar
What about some kind of resistor in the 02 sensor to let it read clear, just like they do with the EGR?
Old Nov 22, 2008 | 07:43 PM
  #45
enutter's Avatar
Nwor?
NWOR =
Old Jan 7, 2009 | 12:57 PM
  #46
tomonthelam's Avatar
I know this is late, but I installed the Downey headers and exhaust on a stock 3.slow last summer. I used the ceramic coated headers and the engine compartment temps are much lower. Ceramic also seems to solve the fuel/brake line issue. I measured them with an IR thermometer and they were OK.
Problems: extracting the cross-over - it can be done with a little creative use of a reciprocating saw to cut off one flange (from underneath, passenger side I believe). Mounting the reed and EGR valves - you may be better off making your own tubes. Turning the nuts is nearly impossible.
Power: definitely noticed more power in the usable high ranges. Flat at lower ranges. Selection of a muffler seems to make the biggest changes. I have gone thru several and this is what seems to affect the low-end torque. Its an overall tuning problem with the entire exhaust system. You get performance, or mileage, but not both.
Mileage: definitely up (low restriction converter in the package).
coleypull15
Nov 3, 2015 07:41 AM
tj884Rdlx
Aug 28, 2015 12:04 PM
clok
Aug 1, 2015 09:42 PM
tobylab
Jul 12, 2015 12:53 PM
Coreyr384
Jul 10, 2015 11:13 AM
