hard to start
Old Feb 2, 2009 | 05:11 PM
galloway's Avatar
hard to start
so i have a 89 v6 3.0 and i got it rebuilt because it went in water. the wire going to my starter went bad so i put a push butten. but now its hard to start. i have gotten it running and when it does it runs fine. i can turn it off and turn and all that jazz. but it seems that if i leave it like over night it is hard to start back up. i dont know whats wrong with it and im in need of help big time. thanks ahead
Old Feb 2, 2009 | 05:44 PM
galloway's Avatar
anyone
Old Feb 20, 2009 | 10:54 AM
Wildcat_4R's Avatar
I seem to be having the same issue with my 4 cyl. Any info would be greatly appreciated.
Old Feb 20, 2009 | 11:21 AM
jpmountainboy's Avatar
what do you mean hard? like cranks slow, or cranks for a while before it fires up. does it click sometimes and not crank at all?
Old Feb 20, 2009 | 11:56 AM
904_runner's Avatar
Hows your battery?
If it starts fine after its been ran for a little but won't start the next day you may have a charging problem, so your battery is struggling to start it.
Old Feb 20, 2009 | 12:06 PM
abecedarian's Avatar
When the key turns, it activates the starter and Circuit Opening Relay (COR) which in turn makes the pump run. If you wired a push-button in to start the truck, and did not put it in parallel with the existing wiring, the fuel pump will not operate while cranking, causing difficulty starting... at least until the engine spins fast enough for the AFM to activate the COR.
If you run a wire from the pushbutton to the appropriate wire from the ignition switch, everything should be okay.
edit- If I'm reading the wiring diagram properly, the 89 V6 should be a solid black wire from the ignition.
skoti89
Jul 8, 2015 12:05 AM
bryan34w
Jul 6, 2015 05:53 PM
colinmil
Jul 6, 2015 04:03 PM
coryc85
Jul 6, 2015 04:07 AM
karbin
Jul 5, 2015 11:37 PM
