hard to start
Old Oct 20, 2008 | 08:59 AM
86blue4runner's Avatar
hard to start
hey guys,
here lately my truck has had a real problem starting. I have to turn the key for at least 30 seconds before it finally starts, then it doesnt want to stay runing. after it gets warm though its fine, but if it sits for any longer than about 10 minutes it does the same thing on start up. do our trucks have a automatic choke that has gone out on mine, or whats going on here?
thanks in advance
Old Oct 20, 2008 | 09:02 AM
bipolarandproud's Avatar
Is the truck EfI or carb'd?If it is fuel injected I'd check the cold start injector ,injector time switch and coolant temp. sensor ,check the wiring also . I don't know anything about carbs. ..I sure someone else that reply's to the thread will. It would probably be a good idea to check for codes.
When my truck did this, I ended up replacing the main relay . .. Just a thought.
Old Oct 20, 2008 | 09:36 AM
its EFI. any info on where these components are, and how to check them would be great.
thanks for the help
Old Oct 20, 2008 | 10:18 AM
coryc85's Avatar
First off, check that you hear the fuel pump when you turn the key to ON. You should hear it engage.
Old Oct 20, 2008 | 10:39 AM
desert-rat660's Avatar
sounds like it could be a bad check valve in the pump, or a fuel pressure regulator, maybe even a leaky injector or more. sounds like your fuel pressure is bleeding off after the car sits. when it starts does it missfire? easy way to check the regulator is to clamp off the fuel return hose, shut the vehicle off. let it sit and then see if it fires up, if not then id look elsewhere
Old Oct 20, 2008 | 03:17 PM
thanks for the help
This might help .
Click on this link for the instruction .
http://www.autozone.com/shopping/rep...00c1528004d5f5
and here are the trouble codes .
Old Oct 30, 2008 | 02:38 PM
86 TurboSR5's Avatar
TSB on cold start timing switch on my 86 turbo truck. Also different or upgraded temp sensor part number. This was cured on 88 or newer 4 cyl i understand. This could help.
Old Oct 31, 2008 | 10:23 AM
mnmontana's Avatar
I would check the cold start injector first. Sounds exactly like the issue. New cold start injector is ~120 bucks @ kragen.com and get the printout (free)+ washers/seals (dirt cheap) from the dealership. Tell them your replacing the cold start and would like the print out and washers, itll be less than 10 bucks.
Old Oct 31, 2008 | 10:40 AM
22mr2's Avatar
A quick check of the cold start injector is quick enough, undo the bolts when its cold and have someone turn over the key, should spray. Its sounds like since its doing it like 10 minutes after shutdown too that your fuel pressure is bleeding off and having to reprime the whole fuel system. Cracking the fuel line @ any fitting after it sits for 10 minutes should spray out fuel, if not, its bleeding down and your on the hunt
skoti89
Jul 8, 2015 12:05 AM
bryan34w
Jul 6, 2015 05:53 PM
colinmil
Jul 6, 2015 04:03 PM
coryc85
Jul 6, 2015 04:07 AM
karbin
Jul 5, 2015 11:37 PM
