Had an accident. Does it need an alignment, or worse...
Old Nov 1, 2010 | 12:38 PM
morena67's Avatar
Man, I'm just a newbie trying to help here...And hopefully I wont get lost in the traslation...but:
-Might be your manual hubs, maybe they were built the wrong way, and when they (it) got hit, something got disengaged.(something means a teeth getting out of the groove).
_I'm saying this, because when I rebuilt mines I used to have a noise coming from the front of my truck...only one side, and that was the problem, I had just to take out the tap of the hub and realign the teeth in the right way...
Good luck...!
Old Nov 1, 2010 | 12:52 PM
peow130's Avatar
My guess would be the fan on the engine hitting the radiator.
I doubt the engine blew the motor, though.
If it was blown then you'd have it knocking all the time.
Old Nov 1, 2010 | 01:13 PM
MudHippy's Avatar
Originally Posted by Zelephant
The thing about this knock is it ONLY occures in drive with the brake on.
I'd be carefully examining the brakes on the side where the impact occured. Making sure the caliper is still firmly attached(mounting bolts tight)and not cracked or broken. And checking that the pads in it aren't damaged/cracked and that the pins holding them in place are still there.
Old Nov 1, 2010 | 02:00 PM
Zelephant's Avatar
Morena- thanks for the tip, I'll have look, but I think the knock is more from the engine bay.
Peow- That's definitely something I'll look at, like I said, noise seems to be from under the hood.
Mudhippy- I'll def. give the brakes a check, don't want to fool around with those. But why would it only happen in drive? I listened closely while riding the brakes backing up, no noise.
Old Nov 1, 2010 | 05:44 PM
  #25
Blair27's Avatar
mudhippy, in your gnarly crash photo, looks like NW Oregon?
Old Nov 1, 2010 | 05:54 PM
  #26
MudHippy's Avatar
Good guess! It's near the top of the #36 trail(Roger's Road)in the Tillamook State Forest OHV Area.
Old Nov 2, 2010 | 08:01 PM
  #27
Blair27's Avatar
i knew it looked close, i live 45 minutes from astoria, pretty similar lookin country!
Old Nov 21, 2010 | 06:36 PM
  #28
hoe_nah's Avatar
oh boy i currently have the same problem with my steering wheel...it sits half a turn to the left and its very annoying haha...idk what it is but i know somethings wrong...im running out of ideas maybe its my center link...but the only thing that annoys me is how when i use my blinker it turns off with a very little turn
Old Nov 21, 2010 | 07:20 PM
  #29
Zelephant's Avatar
Just rent a steering wheel puller from your favorite auto parts store and straighten it. That's what I did, and it didn't affect the throw (left/right balance).
About my accident, I've been driving the truck since I got it aligned with no problems, it doesn't even feel any looser than it was before . The mystery knock comes and goes, but never when not in drive with the brake on. It is NOT the fan hitting the shroud. But no CEL, and I don't have time to worry about it with finals coming up. I just picked up a replacement fender and marker light today, though, and that will be getting painted as time allows.
Old Nov 21, 2010 | 08:14 PM
  #30
hoe_nah's Avatar
by just straightening the steering wheel will that affect my blinker situation?
whenever i put my left signal on and turn the wheel slightly to the left and back to center my blinker goes off...
Old Nov 22, 2010 | 07:51 AM
  #31
Zelephant's Avatar
I'm not sure, since I didn't have that problem, but it's definitely worth a try. If not,my next step would be inspecting or replacing the stalk switch itself.
ladybugRC
458
Aug 21, 2020 10:41 AM
Alexdosdall
Dec 10, 2017 05:48 PM
voiddweller
Sep 28, 2015 11:21 PM
gyroscope7
Sep 21, 2015 04:55 AM
gyroscope7
Sep 13, 2015 05:15 AM
