grrr failed sttering wheel lash inspection.
Old 11-17-2007, 07:26 AM
ken.vs.ryu's Avatar
Thumbs down grrr failed sttering wheel lash inspection.
got my n-05 recall done and I was hoping this would fix it, but it failed again. does anyone have a quick fix for this? how much can I expect to spend?
Old 11-18-2007, 07:11 AM
ken.vs.ryu's Avatar
nada?
Old 11-18-2007, 07:20 AM
Dublin's Avatar
maybe a stupid question but what is "steering wheel lash inspection". Belt too loose, fluid level low? I hate living where there are zero inspections, feels like I'm missing out.
Old 11-18-2007, 08:23 AM
thefallman's Avatar
theres a little screw with a nut on top of your steering gear if you loosen the nut and screw the nut in or out you can adjust the lash slightly i believe. i had a similar problem with mine after i rebuilt the gear until someone told me how to adjust it. so when i rebuilt it again the next year i adjusted it correctly. feels really freeking going down the interstate and trying to change lanes and nothing happens till you get to 1/4 to 1/3 turn
Old 11-18-2007, 08:31 AM
Dublin's Avatar
Don't tighten it too much tough, there needs to be some play or the worm gear will wear down prematurely.
Old 11-18-2007, 09:22 AM
thefallman's Avatar
correct
Old 11-18-2007, 09:39 AM
ken.vs.ryu's Avatar
Thanks!
wouldn't happen to have a picture would you?
Old 11-18-2007, 09:44 AM
tc
tc's Avatar
http://personal.utulsa.edu/~nathan-b.../3onvehicl.pdf
Old 11-18-2007, 02:07 PM
ken.vs.ryu's Avatar
excellent!!!
foampile
12-18-2022 01:29 PM
lectric80
08-11-2015 12:02 AM
GeoRoss
07-24-2015 03:03 PM
jjrbus
07-23-2015 05:05 PM
1994toyota
07-17-2015 03:03 AM
Quick Reply: grrr failed sttering wheel lash inspection.
