Got the Windshield Out
Old Feb 18, 2017 | 06:34 AM
  #61
Co_94_PU's Avatar
Google failed me, but
Yeah Google is failing to turn up the trimming you mentioned, but! It looks like there is a new batch of the molded rubber gasket available.
#56121-89117
From Australia, Link, 107$ (duty fee unknown, expect not included)
From Thialand, Link, 70$ (duty fee not included)
Old Feb 18, 2017 | 08:23 AM
  #62
magnet18's Avatar
If i had known that 2 weeks ago...
I would have done it myself before I called Safelite
Oh well.
Old Feb 18, 2017 | 08:10 PM
  #63
magnet18's Avatar
So...
Ive decided i don't *want* to take a razor blade to that trim unless I have to. I decided I really like the way it looks, and I dont have saltwater worries.
Any recommendations for gluing down those corners?
Ray, i saw you recommend dow 995 http://www.dowcorning.com/applications/search/default.aspx?R=501EN in a different thread, do you have any experience with it? It looks great as a sealant, I just worry about its adhesive properties to the trim. I have some scrap trim i could test on i suppose
3m 08008 weather stripping adhesive seems to be another option, but it looks like it's more for thin layers not a big gap
http://3mcollision.com/3m-super-weatherstrip-adhesive-08008.html
Any thoughts?
Edit
The dow shows a higher pounds per inch peel strength, so if it adheres to the trim that would be the way to go.
Old Feb 18, 2017 | 08:25 PM
  #64
Co_94_PU's Avatar
Originally Posted by Co_94_PU
... Clipped
Window guy will know what to do just make sure he gets the corners of the rubber trim glued in good
Call up Safelite again and find out what he used on the rest of it, they might even let you swing by the store and fix it for free
Old Feb 18, 2017 | 08:57 PM
  #65
magnet18's Avatar
I probably should do that, i know they'll work with me under warranty.
I'm just afraid they're gonna want to pull the windshield again and scratch up my channel :p
Old Feb 18, 2017 | 10:59 PM
  #66
RAD4Runner's Avatar
The 995 was the best silicone I could find - the solvent it uses is non-corrosive - in fact from what I remember it's used to convert rust to good compound.
However, if you can get some of the urethane adhesive they use for the windshield, that would be best. It's the strongest and proven for that application. I took a picture of this inside Safelite's van...
Old Feb 25, 2017 | 08:19 PM
  #67
magnet18's Avatar
Safelite came out to my work Friday and filled the top corners with urethane, taped it down and let it sit 24 hrs, and boom, the corners look great. Plus, this solves the issue of dirt getting in that gap and clogging things up. I'll post up more pics tomorrow after I sand and paint around it.
Old Mar 3, 2017 | 03:39 PM
  #68
magnet18's Avatar
Finally posting up photos of the completed ordeal
I got some rattle can primer on it, to hold me over till the weather is nice enough to paint the whole thing outside (so sad I have to say that )
staying on topic, the glued down trim looks quite good. Installing it curled up and then gluing down looks much better than most others I've seen. Plus the glue seals that little gap at the top, should help prevent dirt from getting in there
Still need to trim the tabs that hold the cowl in place.
