Got a parts truck in WA?
Lookin for a parts truck in Washington to pull efi stuff from for my conversion. I already have my plenum, intake, and wiring harness, the rest of the collection needs to be from one truck... anyone got one? i'm near olympia and have cash
Thanks
Al
Thanks
Al
heres a parts list from another thread
"-upper & lower EFI intake
-injectors
-computer
-harness out of entire donor truck basically
-stock vacuum devices
-EFI evap system
-stock air intake w/ airbox
-knock sensor
-electric fuel pump
-pressurized fuel lines
-EFI fuel filter
-EFI distributor
-(probably) EFI coil
-all required o2 sensors
-Start injector time switch
There's still more thermal vacuum switches and stuff, plus a LOT of relays. THats why, if you're gonna buy parts, try and take it ALL from the same truck/RWD Celica"
i'm gonna need almost all of it from the same truck do you have everything?
-injectors
-computer
-EFI evap system
-knock sensor
-electric fuel pump
-EFI fuel filter
-EFI distributor
ive got the head with 2 cams valvetrain and intake wich is still attatched to the head off a 91 22re with throttlebody fuel rail pressure regulator and ecm its up on ebay tho item #110339446685 take a look if your interested
well efi swap is on hold for now, my dd is going downhill and i've decided to rebuild the motor thanks for the replies guys, i'll probly hit up john or zack in a month or two
Crazy_Guy97
12
Jun 24, 2015 04:02 PM
dirtrider0129
10
Jun 24, 2015 12:24 PM
