good protective oil for fresh 22re's?
I read through a massive thread about oils and the need for adequate zddp and have started using rotella T6. The thing is its a 5w40 and my truck only has about 10k miles on it and I find the 40 weight a bit heavy for my climate (vancouver, BC)
Anyone know of a good protective oil (like the T6) that's maybe a 5w30?
I like Full synthetic especially as the oil is peing pumped through a turbo
Thanks
Thanks
If you want to stick with Shell products, they make a Formula Shell full synthetic 5w30. Rotella T6 is made for diesel applications. If you go the synthetic 5w30 route, then you could probably choose most any brand, IMHO.
The diesel application is good because it has high zddp. most oils do not have high zddp that is required for these high pressure valve tappets/rockers…
If you read my first post I'm looking for oil that has adequate ZDDP
why is 5w40 too heavy for you?
it's a 5 when the engines cold and 40w when the oil and engine is warmed up.
if it gets too cold out you may need a 0w40 or something even stranger.
FS[SouthEast]: Mercury Villager Fan & DCC Fan Controller
coryc85
Sep 9, 2015 06:24 AM
