Going to go look at an '86 runner
Old Jan 7, 2008 | 01:52 PM
shwuz's Avatar
Ok, I have another prospect, and this one actually sounds like it might be a decent value. I've had a second gen before, with the same engine/trans combo, and it was my favorite car ever. I am just looking for some info on what I should be looking for as far as potential problems on a first-gen.
1986 4runner 5spd/22re (hooray!)
The good:
225k miles, seller is original owner
no rust, only minor dings, never wrecked
t-chain done once
working A/C
new clutch slave cyl
new carpet
factory "mags"
aftermarket bumper with hitch
all oil/trans/coolant/etc.. done per suggested intervals
says the top has only been off a half-dozen times or so, and no leaks
The bad:
vinyl seats getting ugly
aftermarket stereo dying
"something squeals on startup" (belts? Fan coupler?)
asking $2200
Sounds decent to me, just wanted some input on if there's anything 1st-gen specific I should be looking for. Like I said, I've had the 22re before, so I know pretty well what to look for there, but other than the motor I'm not too sure. I go to check it out tomorrow morning, so any input is appreciated.
Old Jan 7, 2008 | 02:02 PM
eightnine's Avatar
check for frame rust and general rust everywere since 1st gens rust like no tomorrow
Old Jan 7, 2008 | 02:11 PM
Jay351's Avatar
If you can, get it on a lift and check up the drivetrain, frame etc.
Check for play in the front end. Make sure the suspension is good, does it use alot of oil? Original paint?
Old Jan 7, 2008 | 02:16 PM
TORTIS's Avatar
check all the drive flanges for play, and look at the cv axles, and really look at how much play is at the cv axle and diff on the passenger side. if it is a w56 trans. listen real good in 5th gear for any bearing noise. look inside the rear fender wells for hidden rust with a flashlight.
Old Jan 7, 2008 | 02:19 PM
shwuz's Avatar
Great stuff here, keep it coming!
How to tell if it is a w56 trans?
Old Jan 7, 2008 | 02:29 PM
TORTIS's Avatar
it should because it is a 22re. and it should have atop shift transfer case.
idanity's Avatar
make certain the heater works.
mine barely worked, and smelled like mold. had to replace that (lots of time).
Old Jan 7, 2008 | 02:30 PM
TORTIS's Avatar
a shame your not closer i would sell you mine.
Old Jan 7, 2008 | 02:38 PM
TORTIS's Avatar
shwuz's Avatar
Hell, shreveport's only 6 hours away That's only 3 hours for each of us. PM me if you're serious, tell me whatchu got.
Old Jan 8, 2008 | 06:23 AM
idanity's Avatar
look at his sig/avatar. (less the paint)
whollybolley.
plus, it has a reputable history.
icentropy
Sep 16, 2020 02:47 PM
MTLroadierunner
Jul 15, 2015 12:58 PM
cyclist231
Jul 7, 2015 12:56 PM
Jnkml
Jul 6, 2015 01:20 PM
HRDC0R19
Jul 5, 2015 06:43 PM
