girlfriend won't drive in my truck if i lift it any higher....
ok i recently put a 3 inch body lift on my truck and i wanted to put some ball joint spacers in and some greaseable shackles in the rear and lift it about 5 inches total, run some 33's and call it done for the lift part. right now i am running a 3 inch lift with 31's, my girlfriend said if i lift it anymore she won't drive in it because the truck is too narrow and to high. her dad has a gmc 2500 HD and his truck is higher then mine, sure its much much wider but still, what can i do to change her mind. i am a safe driver and since i got my lift on i do not drive like i have a sportscar what do i do guys???
Get a new girlfriend...
Seriously, I dunno. Maybe take her wheeling, so she sees that street driving isn't gonna be a problem, as long as you don't drive stupid.
Good luck...
Good luck...
X2 on a new girlfriend... that is ridiculous.... You gotta have a girl that enjoys or at least pretends to your hobbies or you can kiss your fun times goodbye. Nothing worse than a woman that spends the next week after you go out to play trying to make you feel guilty.. been there done that...never again.
Anyway, got any pics of your rig? I just stuffed a 3" BL under my '88 4-runner last weekend, and added some adjustable shackles the weekend before that. I had planned on about 9" of clearance between the tire and fenderwell, but now It has a pretty bad 'rake' to it. I'm debating on adding BJ Spacers, or bringing the back down an inch or two (adjustable shackles).
33X12.5 Mickey Thompson Claws will be ordered next week. Don't want to add the BJ Spacers if they're not needed for clearance, you know?
Well I'm 1.5 BJ is front and 2" body lift now with the same rake thing going on, probably 2in higher in back. I plan on doing a flatbed, getting a 3" lift for the cab and lowering the back 1". Over 33x12.5 TSL's.
As far as the girl goes if your serious with her then get some 15x10's and 12.5 wheels. Better yet get some 33x14.5 boggers then ask her if its wide enough.
From: Houston (home), Atlanta (school), Cincinnati (work)
Truck looks plenty high to me as it is though....
Girl's got all her teeth. Those devil eyes are a bit scary, but still....
