Gangsta lean help
Old Jan 22, 2015 | 05:43 PM
GROUNDHAWG's Avatar
Gangsta lean help
Gotta 86 pickup 4x4. Front tires lean and is wearing the inside of my tires out really bad. Ive took it to a alignment shop and they couldn't do anything with it was all they told me. Guy I got it from said he put ball joints on it but when I jack the front end up the wheels have a little play in them. Any help would be preciated. Would like to fix it before I buy new tires.
Old Jan 22, 2015 | 06:02 PM
JasonYota's Avatar
Could be the camber out of adjustment. Any alignment shop could do it. Which part has play in it when you move the wheel?
Old Jan 22, 2015 | 06:12 PM
GROUNDHAWG's Avatar
With the front tires off the ground I can move the whole wheel buy trying to push or pull on it but only maybe a cod hair or so
Old Jan 22, 2015 | 06:20 PM
JasonYota's Avatar
Where are you holding it at? 12 and 6 o'clock would indicate ball joints, 9 and 3 o'clock would indicate tie rods, steering components. Also make sure your preload is set correctly on the wheel bearings
Old Jan 22, 2015 | 06:23 PM
GROUNDHAWG's Avatar
Holding at 12 and 6 and how do u check preload
Old Jan 22, 2015 | 06:28 PM
JasonYota's Avatar
There are threads about it somewhere on here and other sites. You need a 54MM socket also. That's odd the shop said they couldn't do anything about it. Most shops don't work on vehicles over a certain age though.
Old Jan 22, 2015 | 07:08 PM
scope103's Avatar
There's actually a procedure for checking ball joints. Unless you think the engineers who wrote the manual don't know what they're doing, that's what I would follow.
http://personal.utulsa.edu/~nathan-b...28balljoin.pdf You really shouldn't feel looseness; follow the procedure and check it out.
Some vehicles (e.g., McPherson struts) have non-adjustable camber. Your truck is not one of them. If the suspension components were bent too far (collision?), the camber adjustment may be out of range. But it really sounds like the alignment shop you picked just doesn't want to be bothered. Go someplace else.
Old Jan 22, 2015 | 08:19 PM
Odin's Avatar
^^^ I'll 2nd that.
That's pretty lame. I wouldn't go back there again.
Any good shop, hell any shop that gives a damn for that matter should be able to point you in the right direction.
Old Jan 22, 2015 | 10:39 PM
highonpottery's Avatar
Depending on age of parts my guess is a combo of bad bearings preload, control arm bushings and ball joints all contributing. Service front end and see if you can locate a specific problematic area and address it.
Old Jan 23, 2015 | 10:34 AM
GROUNDHAWG's Avatar
Thanks for the info guys
Old Jan 23, 2015 | 11:04 AM
bswarm's Avatar
A good alignment shop will tell you what suspension parts are needed. A really good alignment shop has the camber kits. A crappy alignment shop usually only does toe and blow alignments and won't even check the front end.
Old Jan 23, 2015 | 01:00 PM
scope103's Avatar
If a "camber kit" is what I think it is (shim plates to move the top of a strut or a control arm), it is not needed for this truck. Camber is adjusted with offset bolts in the lower control arms.
To be fair to the alignment shop, they could be "very good," but just don't want to spend the time on a 29-year old truck that will take an hour just to find the specs, and they can't get parts for anyway. They could have plenty of more recent vehicles to work on. It sounds like they didn't charge you. You just need to find the right place; it won't be that hard.
Old Jan 23, 2015 | 01:15 PM
bswarm's Avatar
Some vehicles (e.g., McPherson struts) have non-adjustable camber. Your truck is not one of them. Go someplace else.
Yes they are camber adjustable, you just need to find the guy who knows how to do it. Some adjust at the top plate, some at the strut knuckle, some need a camber kit. Did them all the time.
JonG85
Jan 18, 2023 04:31 PM
Ditch Doc
Oct 27, 2015 03:20 PM
Thamuel_
Domestic Swaps
Oct 3, 2015 11:15 AM
the_supernerd
Oct 1, 2015 09:20 PM
Draven023
Sep 26, 2015 12:41 PM
