gages, windows and ac blow fuse 94 4runner
Old May 13, 2014 | 10:00 AM
nikki8184's Avatar
Hey y'all, i have a 944runner 5 speed that my husband has down a three in body lift on. Well since anout a week or two after he did the lift we seem to keep blowing the fuse that goes to the gages power windows and ac.. we dont even rrally know where to start on this and any ideas yall may have would be a HUGE help.. he dont think it has anything todo with the reverse lights even though they aint workin right either, the fuse blows no matter which way you are going. Also under the dash is some wires and the lead to a box that says shock sensor those aint plugged in can this be part of the problem?
Old May 13, 2014 | 12:51 PM
wyoming9's Avatar
Red face
Hi Nikki welcome !!
It might be possible the body lift stretched some wires to the point they are now shorting
Or in the installing of the body lift things got damaged in some way
Is it the gauges themselves not working or the lights .
I would look around for damaged wires.
Old May 13, 2014 | 01:22 PM
nikki8184's Avatar
Originally Posted by wyoming9
Hi Nikki welcome !!
Thank you.. we have been looking and looking.. the lights arent working but we dont remeber if they did to begin with.. the biggest problem now is none of the gages work(speedo,gas,ect) they arrows for the blinkers come one but none of my needles move and the windows and ac dont work.
Old May 13, 2014 | 02:06 PM
scope103's Avatar
Originally Posted by nikki8184
... we seem to keep blowing the fuse that goes to the gages power windows and ac.. we dont even rrally know where to start on this and any ideas yall may have would be a HUGE help.. he dont think it has anything todo with the reverse lights even though they aint workin right either, the fuse blows no matter which way you are going. Also under the dash is some wires and the lead to a box that says shock sensor those aint plugged in can this be part of the problem?
Which fuse is that? The Gauge fuse provides part of the control power for Gauges, power windows, ac, backup lights, heater, automatic antenna, light reminder buzzer, door locks, seat belt warning light, DRL, ADD, CEL. Are all of those out? (Rather than me guess, you could just look at the fuse.)
Does the fuse blow as soon as you plug it in? As soon as you turn the key to on? As soon as you shift into reverse? When you lock the door, run the window, turn on the radio, shift into 4wd?
Old May 13, 2014 | 02:14 PM
nikki8184's Avatar
Yes all of those you listed are not working and the fuse is for sure blown we have gone though a few just today. It seems to be doing it as soon as we go into reverse..
Old May 13, 2014 | 02:25 PM
wyoming9's Avatar
Red face
Back up Lights go through the Integration Relay as does the Blower Motor
Which also has the 10 amp gauge fuse in the circuit.
If that fuse keeps opening all those things won`t work.
Old May 13, 2014 | 03:48 PM
scope103's Avatar
.... It seems to be doing it as soon as we go into reverse..
See how that easy that was, once you actually describe the problem?
There are two wires into the back-up light switch on the transmission; the R-W goes back to the back up lights (where it changes to R-B at a splice). Somewhere that wire was pinched against the frame grounding it. When you go into reverse you're shorting the gauge fuse to ground through the back-up light switch.
To confirm this, remove one of the back-up light bulbs. One contact is to ground, the other is to the switch. If both have continuity to ground, you've confirmed the problem.
Since (you think) the problem started after messing with the suspension, I'm guessing the problem is where the R-W wire tries to get from the transmission back to the frame support.
Good luck!
Old May 13, 2014 | 05:31 PM
nikki8184's Avatar
To confirm this, remove one of the back-up light bulbs. One contact is to ground, the other is to the switch. If both have continuity to ground, you've confirmed the problemk.
Good luck!
Thanks will try this tomorrow
bigjstang
Jun 2, 2025 03:56 PM
MO transplant
Apr 23, 2023 11:58 AM
Jun 1, 2021 01:51 PM
dpridgeon3
Jul 9, 2015 01:18 PM
coryc85
Jul 6, 2015 04:07 AM
