Fuse diagram question, most likely a stupid one
Anybody have a picture or URL for the fuse diagram for a 87 pickup?
I'm sorting out a parasitic battery drain
, and I need to know which parts my fuses correspond to. I don't have an owners manual, but I'm assuming that's where this info would be. Anybody holding?
However, after the drain I removed and recharged my battery, and reinstalled the battery without the wire from my aux light relay running to the + terminal. That should negate the aux light's ability to draw power from the battery, right? Battery still drained after probably 24 hours.
Yeah, I'm planning on using the multimeter, set to amps, connected between the - terminal and black wire, and start pulling fuses one by one..
This is the process I read about in a previous thread, located here:
https://www.yotatech.com/forums/show...=battery+drain
But, assuming I figure out which fuse it is, I have no diagram to show what the fuse corresponds to.
This is the process I read about in a previous thread, located here:https://www.yotatech.com/forums/show...=battery+drain
Anybody know if the owner's manual has the fuse diagram, or if not where I can find it?
On my truck it's not inside the panels that conceal the fuse box, in case that's where it usually is.
There's a scanned FSM for an '89 at this link:
http://www.brian894x4.com/Scannedmanual.html
Hardy har har. I suppose we're all guilty of it now and then. Sorry for wasted time ya'll.http://www.4crawler.com/4x4/4R_TechI...tml#Electrical
You the man, 4crawler!
theking11863
Mar 19, 2016 09:36 PM
rushw
Jul 18, 2015 01:46 PM
88yodabasket
Jul 13, 2015 01:32 PM
