Fuse diagram question, most likely a stupid one
Old Apr 22, 2007 | 04:58 PM
bad_brains's Avatar
Anybody have a picture or URL for the fuse diagram for a 87 pickup?
I'm sorting out a parasitic battery drain , and I need to know which parts my fuses correspond to. I don't have an owners manual, but I'm assuming that's where this info would be. Anybody holding?
Old Apr 22, 2007 | 05:07 PM
TNRabbit's Avatar
Do you have an aftermarket trailer light kit or radio? I can almost guarantee that's where your problem lies.
Old Apr 22, 2007 | 05:13 PM
bad_brains's Avatar
I did install some Hella 500 aux lights on the front.
However, after the drain I removed and recharged my battery, and reinstalled the battery without the wire from my aux light relay running to the + terminal. That should negate the aux light's ability to draw power from the battery, right? Battery still drained after probably 24 hours.
Old Apr 22, 2007 | 05:16 PM
TNRabbit's Avatar
Do you have a multimeter circuit tester?
Old Apr 22, 2007 | 05:26 PM
bad_brains's Avatar
Yeah, I'm planning on using the multimeter, set to amps, connected between the - terminal and black wire, and start pulling fuses one by one.. This is the process I read about in a previous thread, located here:
https://www.yotatech.com/forums/show...=battery+drain
But, assuming I figure out which fuse it is, I have no diagram to show what the fuse corresponds to.
Old Apr 22, 2007 | 06:36 PM
bad_brains's Avatar
Anybody know if the owner's manual has the fuse diagram, or if not where I can find it?
On my truck it's not inside the panels that conceal the fuse box, in case that's where it usually is.
Old Apr 22, 2007 | 06:42 PM
TNRabbit's Avatar
There's a scanned FSM for an '89 at this link:
http://www.brian894x4.com/Scannedmanual.html
Old Apr 22, 2007 | 06:45 PM
bad_brains's Avatar
Hardy har har. I suppose we're all guilty of it now and then. Sorry for wasted time ya'll.
http://www.4crawler.com/4x4/4R_TechI...tml#Electrical
You the man, 4crawler!
theking11863
Mar 19, 2016 09:36 PM
Poppie51
Jul 23, 2015 05:03 PM
rushw
Jul 18, 2015 01:46 PM
Poppie51
Jul 16, 2015 06:16 PM
88yodabasket
Jul 13, 2015 01:32 PM
