fuel pressure pulsation damper 94 4runner v6
Old Jul 15, 2009 | 08:04 AM
4UNER's Avatar
how many and what parts will i have to remove to replace the fuel pulsation damper
Old Jul 15, 2009 | 08:25 AM
SkiRig's Avatar
You won't be happy....the top of the intake manifold has to come off. Bare minimum all you need to replace is the intake plenum gasket. but, it would be a good time to service the injectors and set the valves.
Old Jul 15, 2009 | 11:38 AM
CILO's Avatar
Dumb question:
What do you mean by servicing the injectors and setting valves? whats involved?
Old Jul 15, 2009 | 01:37 PM
TNRabbit's Avatar
Setting valves is a GIANT PITA; if they are close, I wouldn't change anything.
Servicing the injectors would be pulling them and sending to someone like http://www.witchhunter.com/index.php4 for ultrasonic cleaning & replacement of all the grommets/o-rings. It's WELL WORTH IT.
Old Nov 27, 2010 | 06:12 PM
BeenYota's Avatar
dude's fuel leak in the garage. thinkin it's the damper. gonna be fun investing time in something so gay. Anyone here know of a write-up on this so i can get an idea on the kind of time i'll need?
Old Nov 27, 2010 | 07:22 PM
MudHippy's Avatar
1. The EGR valve and the intake plenum chamber stay/bracket will need disconnected/removed. Disconnect the 2 coolant hoses running to and from the bottom of the throttle body and the 2 heater hoses at the front and rear of the intake plenum chamber. Unplug the TPS and the rear engine ground strap from the intake plenum chamber. A couple vacuum hoses(1 on top of the throttle body mark "P", 1 on top of fuel pressure regulator)and atleast one fuel line(fuel pressure regulator)will need disconnected. Disconnect the accelerator cable from the throttle body and remove it from the intake plenum chamber clips. Disconnect the hoses for the intake silencer and air filter box resonator from the intake plenum chamber. Disconnect the air intake hose from the throttle body. Then unbolt the intake plenum chamber. Lift the intake plenum chamber off the intake manifold and set it aside leaving the throttle body and as many hoses and wires still connected to it(passenger's side)as possible, while leaving enough space to access the fuel pressure pulsation damper.
2. Unscrew the fuel pressure pulsation damper from the end of passenger's side fuel rail. Replace with a new one using new copper gaskets. If the unit itself isn't the cause of the leak, then you may be able to just replace the copper gaskets.
3. Place a new intake plenum chamber gasket on top of the intake manifold. Set the intake plenum chamber on top of that and bolt it securely to the intake manifold. Reconnect the EGR valve, intake plenum chamber stay/bracket, and all hoses and wires.
4. Run the engine with the heater on and the radiator cap off untill the upper radiator hose is warm, to circulate coolant through the system and remove any trapped air(necessary because you'll have disconnected/reconnected atleast 4 coolant lines for the throttle body and heater core in the process). Check the coolant level and refill if needed. Put the radiator cap back on.
5. Your done.
More info/details can be found in the link below.
http://personal.utulsa.edu/~nathan-b...68cylinder.pdf
There's your write-up. Shouldn't take more than 4-5 hours even if you take your time. It would take me less than 2, because I'm very familiar with how to remove/replace the intake plenum chamber efficiently.
Old Nov 27, 2010 | 08:59 PM
BeenYota's Avatar
You're the fecal MudHippy! Just sitting back down to research and there it is.
Old Nov 28, 2010 | 02:01 PM
MudHippy's Avatar
Here's the stuff I forgot, diagrams and part #'s.
17176 GASKET, AIR SURGE TANK TO INTAKE MANIFOLD
17176-65020 3VZE
23270 DAMPER ASSY, FUEL PRESSURE PULSATION
23207-65010 3VZE
23270B GASKET (FOR PULSATION DAMPER HOSE)
90430-18028 3VZE
23807J GASKET, PIPE FUEL DELIVARY INLET
90430-18028 3VZE
Old Nov 28, 2010 | 05:19 PM
That Guy's Avatar
i just got done replacing mine last weekend. its not horrible to do but its some work, I ordered a new one from the dealer $146 i believe. I also took the opportunity to replace my leaky valve cover gaskets while i was in there and also the pcv valve and some vaccume lines. good luck
Old Jul 3, 2013 | 11:43 PM
rikd72's Avatar
Exclamation Damper replacing without intake removal.
Remove the hood. Remove coolant hoses and sensor closest to the damper. Also clearing all wiring and vacuum hoses nearby helps. I broke the vacuum hose nipple going to the charcoal canister. First remove the driver side fuel line going to the back of the engine(23802B)The banjo under the plenum is just forward and above the damper.(Screws in straight down).Caution not to slip or bend fuel line. A stuby ratchet wrench works well. Then loosen the other end adove left valve cover. Remove bolt that secures the passenger side fuel line(23811B) just behind the valve cover. A 23mm crows footusing shortest extension possible helps break loose the damper if you plan on re-using the existing damper. A wrench will work, but damage the damper. I was able to use the banjo gaskets several times cleaning the surfaces with fine sand paper. Less torque is required if using new gaskets if a wrench is used to secure. Be sure to line up the hold down bracket before you torque down. I will upload some pictures if needed.
Old Jan 4, 2015 | 09:47 AM
dleehawaii808's Avatar
hi
Can't I just screw the old one out..and put the new one in?? I'm doing my fuel damper today....
Old Jan 4, 2015 | 10:20 AM
scope103's Avatar
No. You can't reach it.
I don't know how MudHippy manages to remove the FPD without removing the cross-over fuel pipe as well, but he may have a clever wrench that can fit in there.
It ain't that hard; just suck it up and be systematic as you work your way in there.
Old Jan 5, 2015 | 08:14 AM
NickB47's Avatar
Depending on how many miles are on your engine, you may want to adjust the cam-shim gaps at the same time. Apparently this is an area of potential failure on these engines as they tend to wear outside their limits over time. Not that much more to do since you've already got the manifold off, but there are tricks. Lots of info on this in the forums and in the FSM.
Old Jan 5, 2015 | 08:37 AM
hawaii
Well I install the new fuel damper. After market peace.... Straight metal but use da same crush washer on da damper. . Put everything back together and shoots gas now... u think it could be da crush washer
Old Jan 5, 2015 | 08:57 AM
scope103's Avatar
dlee-
Try proof-reading your postings before you send them; it will make it much easier for others to understand. "After marker peace"? "da damper"?
Also, asking the same question repeatedly in different threads doesn't help much either. If you don't like the answer you got, explain why and someone else might be able to fill it out.
And yes, since you reused the crush washers, that's almost a guarantee of failure.
Old Jan 5, 2015 | 09:02 AM
Originally Posted by scope103
dlee-
Sorry under the hood and and posting...ya dats all I need to know .. thanks...
bigjstang
Jun 2, 2025 03:56 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
steve miller
Oct 10, 2015 01:40 AM
karbin
Jul 5, 2015 11:37 PM
HRDC0R19
Jul 5, 2015 06:43 PM
