fuel/air no start mystery help
Old Aug 20, 2008 | 02:22 PM
abecedarian's Avatar
according to 4crawler,http://4crawler.com/4x4/CheapTricks/AFM/index.shtml, E2-VS should be 20-400 ohms with the vane closed and sweep up to 1000 when the vane is fully opened.
looks like an afm problems
Old Aug 20, 2008 | 02:42 PM
bigt's Avatar
on both toyotas!! that would be amazing if it was that simple..
but i just dont understand how my daily driver could shut off whlie driving never to start again... ill get a good used afm from my yota part hookup...
but im still going to look at the bj-70
Old Aug 20, 2008 | 04:12 PM
bigt's Avatar
also would a bad afm cause no starting on my daily driver???
Old Aug 20, 2008 | 04:24 PM
possibly. if it's giving the ecu the incorrect air flow reading it could, which the E2-VS reading is.
Old Aug 20, 2008 | 04:32 PM
  #25
bigt's Avatar
ok cuz with no codes and both afm reading the same i guess i cant test any further!! ill get 1 good replacment and try it on both trucks.. the trail rig backfired out the snorkel so i would suspect the afm there too but no codes really puzzles me!!
Old Aug 20, 2008 | 06:22 PM
  #26
thook's Avatar
Well, if it's any consolation, I had a bad AFM with no related codes. Just a code 5 for the O2 sensor..........which disappeared finally after replacing the AFM.
Old Aug 21, 2008 | 07:33 PM
  #27
bigt's Avatar
still waiting on a afm
heres the last mudhole i hit before it went bad.
http://www.youtube.com/watch?v=KHDHs...pic3330-10.php
Old Aug 22, 2008 | 10:40 AM
  #28
bigt's Avatar
dealer wants 1300 for afm i need 2...
this SUCKS no junkyards near me have any runners
i guess ill try and clean them
Old Aug 23, 2008 | 01:38 AM
  #29
4wheeler808's Avatar
If Its A Fuel Problem..........check Both Relays For The Fuel System.......those Relays Broke Most Of The Time...........
Check The Connectors Leading To The Fuel Pump............could Be Loose...........
It Happen To Me Before...........
The Thing Just Die Out While I'm Driving............
Doug4320
Mar 24, 2018 10:11 PM
Yota.Jay
Jul 23, 2015 08:08 PM
ZONAYODA
Jul 13, 2015 07:17 PM
Poncho0206
Jul 10, 2015 06:21 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
