Front splash guards
Front splash guards
I own a 1990 4x4 T4r and after sending it thru an automated car wash found the splash guards did not handle it well and I have not be able to locate the front splash guard replacements and thought I would check with Yotatech community for a possible source.
Comment/suggestions appreciated!
Thank you, dave
Thank you, dave
They seem to show up on eBay. https://www.ebay.com/itm/Toyota-4Run...-/163261224610
Do these fit? I usually go to a dealer website to check for year-year fitment, but since Toyota no longer makes these that option isn't available.
https://parts.lakelandtoyota.com/sho...rimLevel=18380
https://parts.lakelandtoyota.com/showAssembly.aspx?ukey_assembly=519665&ukey_make=1 060&ukey_model=15426&modelYear=1994&ukey_category= 21641&ukey_driveLine=6747&ukey_trimLevel=18380
I have set up daily ebay email notification when this particular item comes up for sale if no luck in reasonable amount of time I will check to either refab a set using the old as templates, or try and repair the originals.
Greatly appreciate the input!!.
A fender-apron "seal"?
Lakeland's website says they're still available, but if you care, you should call.
More importantly, as far as I can tell they are nothing more than some toughened rubber sheet, that you probably could cut with a pair of good scissors. At $20-$70 a piece (plus shipping), I'd start by looking to see if I could source the plain sheet. Making the holes (neatly) is non-trivial; I'd clamp it between two pieces of wood and drill through the sandwich.
The fasteners (at least ones quite close) are available from Dorman. Your local parts store probably has a rack of Dorman parts.
If you have a local junkyard you could try that and as scope said easily made from rubber or even an old set of rubber floor mats
Also a cheap set set of punches from harbor freight are amazing at punching holes in things.
But with my OCD a factory part if available is always my first choice.
https://parts.lakelandtoyota.com/showAssembly.aspx?ukey_assembly=495045&ukey_make=1 060&ukey_model=15426&modelYear=1990&ukey_category= 21641&ukey_driveLine=6747&ukey_trimLevel=18380
I left a message with the Toyota salvage yard out of Colorado but have not heard back from them as yet.
I intend to take the diagram from the Lakeland site and compare to the splash guards currently on the vehicle, appears the Lakeland catalog only list 1 splash guard for the passenger side, I believe there are at least 2? Will contact them to confirm they still carry the items once I have determine which guards I need.
I want to thank U's all for the links and suggestions!!.
