Front end super bouncy
Old Jul 19, 2022 | 07:26 AM
harborarea's Avatar
Hello
recently purchased a 90 2wd with a 2.5 inch lift
the lift uses ball joint spacers in the front and coil spacers out back … front end bounces excessively
i replaced the shocks recently with some skyjacker blackmax shocks thinking it would fix the problem
unfortunately it did not. Will the spacers cause the ride to bounce like that? I also replaced ball joints and control arm bushings
any help would be much appreciated
Old Jul 19, 2022 | 11:12 AM
Melrose 4r's Avatar
5 Year Member
When you say “super bouncy” you mean it’s too easy to bounce up and down?
i run ball joint spacers on mine and don’t have that problem. I wonder if the person who installed them loosened up the torsion bars to compensate for the lift. You could try adjusting them.
Old Jul 19, 2022 | 11:28 AM
harborarea's Avatar
Thanks for responding.. anytime I hit a significant dip or bump the front end feels like it slams hard then proceeds to bob up and down for a few seconds after
so you would suggest to check the torsion bars and tighten if necessary?
Old Jul 19, 2022 | 06:51 PM
Melrose 4r's Avatar
5 Year Member
Yeah unless the shocks are simply not up to the task, torsion bars are the only thing i can suggest.
CapeRustBucket
Apr 25, 2010 06:10 PM
adams707
Oct 7, 2009 09:03 AM
SWORDFISH92
11
Aug 12, 2004 03:52 PM
Ilovemountains
Jul 22, 2004 11:28 AM
