front dash speakers...
Old Dec 3, 2008 | 03:04 PM
Tubbyfatty's Avatar
Originally Posted by Blurr
it will take a little time but you you can run the wires through the existing rubber hose conduit in the door jamb
Ah, what did you use to cut the holes? Dremel?
Old Dec 4, 2008 | 08:18 AM
Blurr's Avatar
i used a utility knife to cut the speaker hole in the door panel and a dremel to carve the semi-circle out of the pocket.
Old Dec 15, 2008 | 10:43 AM
poynter's Avatar
i would avoid putting any speakers in the front dash location because you are limited to a 4" speaker and it points down at your legs, not good for optimal sound quality. i put components in the door panels and never looked back
Are those 5 1/4"s?
I was wanting to do the same thing but wasn't sure what kind of depth I had to work with in that same exact spot without interfering with the window.
Old Dec 15, 2008 | 02:16 PM
Cyberman's Avatar
Looks more like 6" or 6 1/2".
Old Dec 16, 2008 | 05:46 PM
  #25
NYChopshop's Avatar
Look at MB quart's 4" component sets, I'm getting the PVI 210s. Thats 2x 4" drivers, 2x tweeters, and 2x crossovers. Those crossovers will allow you to ADD a 6" woofer after the fact and put it in the door like the pictures above. One of the better one's I've seen didnt slice up the map pocket, but slid it back some putting the driver in the lower front corner of the door. You can also go back and add the driver later when if you decide to get a stand-alone 4 channel amplifier like I do. 6" drivers are great for mid-bass, but not until you pump enough wattage for the speaker to make all the excursion it needs to in order to produce those lower frequencies at any volume. The 4" components, especially if your stock amplified rear components still work, should totally be enough sound to make you happy for the interim until you decide to build upon and not replace your upgrades. there should be 2x drivers in the trunk on the sides and 2x tweeters on the roof right by the rear window. If those are blown, bypass the amplifiers and get another component set. At any rate, if you use the amplifier built in to a dash mounted head unit, then you arent getting any more than 30 or so watts RMS per channel. My eventual plan will include a 4 channel amplifier powering a 3-way tweeter-4"driver-6"driver set in the front and a 6" component set in the rear (tweeters in stock location and drivers in rear doors, even though the closer the components together the better because distance to ear is similar). I will NOT be using the stock rear amplifiers, or the amplifier built into my head unit, and my 4-channel will put at least 75 watts RMS per channel. A 2 channel amp will power 2x 6" JL audio 6" subs installed in the stock trunk locations, probably modified slightly to have the proper sealed air displacement. This won't give me low bass and I'd eventually like to add the JL 13w7 single sub in a box for some earth-shaking bass. I'd put the 2 amplifiers under the front seats (I've seen them mounted on the roof of the trunk looking pretty slick) if they fit and sacrifice one of my rear cargo pockets to fit the sub amp for the removable JL sub box if and when I get the cash together for that sucker! I highly recommend both boston acoustic and MB quart for speakers, and always get component sets over coaxial if ever you can. The sound is always better, some may argue not noticeably, but I'm a sound engineer by trade and build recording studio speakers - components are always better. I swear by JL audio for subs (and usually the matching amps) unless I'm throwing thousands and thousands into that kind of bass that changes you - like in a show or competition car (of which I've built a couple). If you want top of the line for the bottom lowest bass, look into memphis audio. Other than their best with thousands of watts of amplification, I'd say stick to JL audio.
Old Dec 16, 2008 | 06:18 PM
  #26
NYChopshop's Avatar
Originally Posted by space-junk
not higher quality persay but a higher wattage... go with 100W MINIMUM speakers if you like to crank the stereo...
and in order to run speakers in the pockets, all you would need to do is tap into the dooe speaker outs off of the wiring harness by the head unit...
also, dont bother installing "bass blockers"... while they do serve a purpose, a better idea would be to find a manual for your head unit and see if it has a high pass filter... otherwise known as a defeat... that will make all the speakers cut the bass except your amp will still be sending the proper signal to your subs... trust me, your speakers will like it... and if your head unit doesnt have one, then id think about upgrading it... even the 30 dollar stereos at the flea markets here have high pass filters build in...
one other thing to consider is that JBL subs, including the low end ones, like to be powered... your running a 300W amp to 2 10's that should be getting about 300 a PIECE!! now considering that the kicker amp runs about 140W RMS, id get another one and run them off of a distribution block off of some 4 gauge to the battery with a 2.0 Farad cap...
I agree with basically everything you say. Capactiors are great if you are using stand-alone amplifiers, I always use them. I like to keep a single battery setup when possible, leaving more room for everything else! I have a K5 with a similar setup, branded differently. Its a 5.7. I ran 4 speakers off of the head units amp and a memphis belle 5 channel super balls-out amp. thats 75w x4 @ 4 ohms RMS + 1100w x 1 @ 1 ohm. I have that run to 2x 6" component sets in the doors and rear, and a couple memphis subs. Fun Fun FUN!
Bass blockers are basically a resistor that you wire inline with the + to a speaker, filtering out the low end. Unnecessary if you have a high-pass option built into your head unit as most do that have a sub-out. Also unnecessary if you run your stuff through a graphic EQ like Kenwood's KGC-4042A, but most people don't. If you're not a smoker, you can put one of them in place of your ash tray. Crutchfield gives you a pretty good look at it: http://www.crutchfield.com/p_1134042...2A.html?tp=116. It acts as a low-pass filter for your subs and a high-pass filter for your speakers at the same time.
I also agree on the wattage. If you get yourself the 2-way components for the rear to put in the doors or stock location, and put a 3-way component set in the front, you can get all the power and definition you want and comply with that 100w rms. You just may not need or want to do that especially when you have subs already to make up for the low end significantly. I say start with what you can put back behind the upholstery (with the exception of the addition of a separate tweeter in the front). You can always pour money into it, and if you're careful about what you buy, you may never find a purchase being unused.
Old Dec 16, 2008 | 08:46 PM
  #27
Blurr's Avatar
Originally Posted by poynter
Are those 5 1/4"s?
they are MB Quart 6 1/2 components. no way would those speakers have cleared the window internals without spacers, i got some angled ones off ebay.
Old Dec 16, 2008 | 10:47 PM
  #28
NYChopshop's Avatar
there are some nice looking spacers here, in fact I'm getting these gray ones to match my interior.
http://www.aerpro.com/list.php?pcode...no=08&cat_sno=
Old Dec 17, 2008 | 02:52 AM
  #29
poynter's Avatar
Do you have any idea what kind of depth you have without the spacers?
Old Dec 17, 2008 | 10:20 AM
  #30
NYChopshop's Avatar
Its generally hard to figure that thing out and measure, pop your door panel off if you're curious and roll the window down. It depends on the shape of the speaker as well. If you can get one of those rubber speaker buckets that seals the speaker off that will help asl well. Not to mention keeping the speakers dry if for any reason you just so happen to get your toyota wet
Old Dec 17, 2008 | 10:35 AM
  #31
NYChopshop's Avatar
Yotatech member OSIRIS did a really nice install and posted everyting. Here's a link to his thread:
https://www.yotatech.com/forums/f96/...runner-116183/
Also, here is a link to a .PDF file by installdr.com that walks you through the whole thing:
http://www.installdr.com/InstallDocs...PDF/869017.pdf
Another option for stock-ish looking installs is to make the whole trunk side into a sealed sub box like this guy. I like it, but I'd rather have the storage space and a removable sub for when the mood strikes me.
http://www.cardomain.com/ride/296763/1
Old Jan 1, 2009 | 08:44 PM
  #32
NYChopshop's Avatar
so what did you end up doing with your stereo?
Old Jan 2, 2009 | 11:07 AM
  #33
Tubbyfatty's Avatar
I just ended up getting some 4'' speakers i got for cheap at stereo king.
http://www.crutchfield.com/p_113KFC1...tml?o=r&tp=102
Ive bought a lot of stuff from them and they know me so they took i think $25 off the price.
Old Jan 2, 2009 | 08:15 PM
  #34
rangerruck's Avatar
anyone know where the front speakers are, on a 88 4rnr? also what is the size of the factory speakers? thanks.
Old Jan 2, 2009 | 08:47 PM
  #35
Tubbyfatty's Avatar
Lower dash by the doors? mine are 4''
http://www.crutchfield.com/cgi-bin/a...r%2fMyCar.aspx
Enter your stuff and it should tell you all the sizes of your speakers around your rig.
88sasturbotoy
Jan 30, 2026 01:57 PM
ashersullivan88yota
Jan 18, 2022 05:37 PM
jasonty
41
Dec 23, 2018 01:00 PM
coffey50
Jul 28, 2015 10:55 AM
jetspeedz
Jul 13, 2015 09:32 PM
